20 Most Recent
Bebecar Raider AT Stroller Questions & Answers
Need info about folding a bebecar raider at
To fold the Raider AT you need to turn the twist grip in the centre of the handle in the direction of the arrow. The secondary lock is located just below the rubber handle grip on the right side, slide this up. You can obtain instructions by emailing
[email protected]
How do i put a folded bebecar pram up to use
Press the central red button on the handle and twist on the twist grip. Place your foot on the horizontal bar (that the basket is attached to) and push down on that at the same time as pulling upwards on the handle, until the chassis is locked in.
You can obtain instructions for your Raider AT by e-mailing
[email protected]
Doh!! Clueless!
i have a copy of the instruction leaflet..if you email your address I'll send you a copy
I am unable to fold
hiya i have just got the same pram/pushchair n mine was already set up i have had a nighmare to fold it affter reading how to on here it still seemed jammed i just give mine a little wiggle n it folded, hope this helps x x x
Hello i have the bebe car multipla at (vogue
Whereas the Multipla chassis had front wheels that could swivel by 360 degrees, the Multipla AT had steerable front wheels designed to turn in parallel with each other, by several degrees in either direction, when set in 'steering' mode, or to remain fixed, when in 'fixed' mode, the mode being controlled by a plastic button on the side arm. A set of instructions relevant to your particular model is available from
[email protected].
How to lock the front wheels
On the Raider AT+ is a tab on the side of the chassis. Operate the lever down to put the front wheels into steering mode, and up for non-steering.
An instruction manual, with diagrams, is available from
[email protected]
Cant fold the urban tracker down
To fold a Raider AT pushchair, first make sure that the front wheels are locked into the non-steerable mode. Next, look at the twist-grip in the middle of the handle. Press the central red button and simultaneously turn the collar in the direction of the arrow. The chassis should begin to close at this point.
Then find the lever on the side that operates the secondary locking device. Tilt the chair forward and continue folding until it is fully closed. It may be necessary to align the front wheels with your foot in order to enable the chair to close fully.
An instruction manual, with diagrams, is available from [email protected]
Im having problems figuring out
[email protected]
I have a bebecar adventure
The harness is removeable however we need to identify the exact product you have before the correct advise can be given. If you email
[email protected] will the model name they will be able to forward you the correct instructions. You can also speak to an engineer by telephone on 01692 408807
I can not fold my bebecar raider at stroller
Firstly, remember to lock the swivel wheels in the non steering
mode before folding chair.
To fold, firstly press the red button and simultaneously, turn the handle collar in the direction of the
"FOLD" and the chair will begin to close.
Operate the secondary safety device by pulling the plastic tab.
Tilt the chair forward and continue the folding action until the chassis is fully closed. Why not ask for a user manual at
[email protected]
Have a bebecar sport 2 n 1 system 4 wheeler the
You'll need to narrow your description of this broken clip down a little more. "Sport" is actually a fabric design, whereas you'd need to sepcify a chassis model, such as "R-Versus", "Stylo", "Vector" or "Multipla", etc. etc. Also, how old is it? Your best bet would be to get in touch with
[email protected]. They may ask you to provide a photograph of the broken clip, if they're unable to work out what it is from the description. Good luck!
I have a second hand Bebecar adventure raider
To unfold the Raider, first press the red button in the middle of the handle and then twist the twist-grip in the direction of the arrow. Once you've done this, keep it twisted while you place your foot on the horizontal footplate. Once the chassis starts to open, pull sharply on the handles until both the primary and scondary locks engage. Make sure that the red latch is not visible, and check the security of the primary and secondary locks by gently pulling on the handle and pushing on the left and right mouldings.
Find out more by requesting a user-guide from
[email protected]
