20 Most Recent
Rockford Fosgate T15001BDCP Car Amp Questions & Answers
Amp was playing fine. Was unhooking speaker and
Maybe, but you would need to take it to a stereo repair shop. If a wire is burned out or a small component is blown, it can potentially be replaced. May be cheap and easy, or may be too expensive to repair for the cost of the amp.
Amp worked fine on the
Check the ground wire. It should be solidly connected to the vehicle chassis in a paint-free location. It may have come loose, which would cause the amp not to power on. Also check the fuses, both in the amp itself and in the in-line fuse by the vehicle battery, along the live power wire. If they are blown, the amp will not receive power.
2 12 p3d212 2 ohm hooking up to a rockford
Hello a_brake11,
The P325.1 is relatively small to power a pair of P3's. You'll only get 325 watts RMS at 2 ohms (162.5 watts per sub). The P3's power range is from 100-500 watts, so they will work, but don't expect them to be really loud.
For best power, your subs should be wired with the voice coils in series and then the 2 subs paralleled to the amp resulting in a 2 ohm load.
Hope this helps.
I have a Rockford Fosgate 1500 BD amplifier and terminals for the power cable will not loosen or tighten how do I fix it
First off will the fastener turn ? If not try using a bit of wd-40 and letting it "soak" for a little while . Also be sure you are using a good proper sized Phillips screwdriver . If the fastener still won't turn try using a can of "computer duster " inverted so the liquid comes out , note this will be well below zero degrees , and freeze the screw head , then try turning . If the fastener is stripped and the ttol slips you will have to remove the amp cover and grip it with a pair of vise grips ,pliers or a flat blade screw driver .
