20 Most Recent
Ricoh Aficio 2228C Copier Questions & Answers
Fusing unit setting error
To prevent damage to the machine, the main machine cannot be operated until the fusing related
SC has been reset by a service representative.
? Enter "SP Mode 3" in the SOM.
Click "OK" in "Reset Fusing Unit SC" with "SP Mode 3", and then turn the main power switch off
and on.
Print driver (2228C PCL 5C)
Remove the data cable from the back or size of the printer. Turn the printer on and let it cycle. Then plug back in the data cable. It should show a green light by the cable if you are reconnected.
Question about my color copier
Replace the yellow drum unit..... Or have your service person come out and do a general cleaning on your copier.. Good Luck
How do i fix the black streak in my coppies
Could be many things. Maybe as simple as cleaning the **** glass under the feeder if it only happens when using the document feeder but not when making a copy from the glass. If both copies from the feeder and the glass have lines then it is probably coming from the drum or fuser area inside the machine.
The copier is showing an
Check that the cable unit duplex reversal is connected.
Replace the PSU if no power is supplied to the devices.
Replace the control front and back of the unit of inversion.
What does trouble code "SC
Hello Ryan,
It means your device went thru a self check in an effort maintain optimum copy quality. Your device could not get Magenta (pink/red) to even get close to the target values for that color. The most likely cause (and we hope so) is the Magenta development unit is toast. Replace it. But of course there are a myriad of other fun causes. As a sidebar, you might want to consider replacing yellow and cyan at the same time as they tend to croak at pretty much the same time. You have a quite reliable device as a rule. It's worth the cost. Take care. Let fixya know I helped ya please. SPINAL
How to access sp5 on
the only way I can help you is to give you a service manual.
The service manual is for 3800C but it`s the same machine.
You can download the manual by clicking
HERE.
We have an Aficio 2238C that is giving an error
Probably this happened after a paper jam??? Yes???
This error is related to the Tranasfer Unit.
This SC 471 can be cleared by removing and re-installing teh Transfer Unit.
If this doent work you probably have to replace a mylar. For that i advise you to call a technician
How do I replace a drum on a ricoh aficio 2228C
It very easy...:) if you have a drum in hand.
Open the front cover. Lift one big green handle. Untainted 2 big black screws and open the drum cover. There you will see four groups of drum+development unit. Pull out the needed drum and pull in the new one. Then close all covers and that's all
pifonski
We have a proplem which
Hi the only advice i can give you is to calibrate the machine you may need to use something like an es100 calibration unit to correct the color issue and keep it stable
