20 Most Recent Alvarez Yairi DY84C Cutaway Rosewood Dreadnought AcousticElectric Guitar Natural Questions & Answers
ALVAREZ 35666DY46
To get your answers contact Alvarez at this link- Contact Alvarez Guitars
3/8/2016 1:41:57 AM • Alvarez Yairi... • Answered on Mar 08, 2016
2answers
My Alvarez guitar model RD-30SC N the strings buzz when I play. Is this easy to fix?
Strings buzzing can either be the action being set too low, or the frets needing dressing or the neck not having enough relief or being actually warped. We can't tell from here. https://acousticlife.tv/fix-your-acoustic-guitar-buzz/ https://acousticguitar.com/ask-the-expert-why-is-my-guitar-buzzing/ Learn how to adjust the truss rod in your guitar, if you can. That's the easiest fix that does not involve specialized tools, filing frets, or disassembly. You may need to buy or borrow a long hex driver to reach the truss rod adjusting nut https://www.youtube.com/watch?v=xyqrSRI2asc&feature=youtu.be&list=UUM-CsUeK57J8grv9BSBRRhQ If it is a simple relief problem, that may fix it. Adjusting the height of the bridge requires taking out the bridge and shimming it, which involves some woodworking skills (unlike an electric guitar where you can adjust bridge height and intonation with screwdrivers and or hex wrenches) https://www.haloguitars.com/store/blog/what-causes-fret-buzz-and-how-to-fix-it/ https://breedlovemusic.com/acoustic-guitar-blog/how-to-fix-and-avoid-fret-string-buzz-on-a-acoustic-guitar This should be possible to fix, depending on the cause, but because this is an acoustic guitar adjusting the action, frets and any major neck issues is a job that should be looked at by a qualified person. Keep in mind that your Alvarez is not a hugely valuable guitar, so you want to set a budget and get an estimate.
8/8/2023 9:54:10 PM • Alvarez Music • Answered on Aug 08, 2023
Is there a manual for an Alvarez mpa70 e guitar
4/17/2023 2:58:23 PM • Alvarez Music • Answered on Apr 17, 2023
Alvarez Guitar. What is the date and specs of an Alvarez guitar with Serial No. 56487? Thanks.
Question edited for clarity. They aren't easy to date. See the first link. Ask them direct. Also there are MANY models and you give no clue.
Alvarez guitars - Jedistar
Jedistar https://jedistar.com > alvarez Serial number appears to have an A before numbers and then 5 digits like yours, 81613. It's stamped into bracing on the back piece, no sticker. Mine is ...
Alvarez Guitars: Home
Alvarez Guitars https://alvarezguitars.com Which guitar gives you unsurpassed value and quality? Which guitar is the one you keep reaching for? We believe that guitar is Alvarez. Why Alvarez. Featured ... https://www.google.com/search?q=alvarez+serial+number+lookup ..
4/10/2023 12:39:46 PM • Alvarez Music • Answered on Apr 10, 2023
Serial #30927002 Alvarez acoustic guitar model # RD10 what year is it
Up to around 2000 the series was split into Regent Standard models with the lower model numbers (RD10, RF20, RD20) and Regent Deluxe models (RD30, RF30, RD50). Date of Manufacture: 2001
1/3/2020 4:59:35 PM • Alvarez Music • Answered on Jan 03, 2020
My Alvarez guitar model RD-SC30 N has a buzz when I play. Is this easy to fix?
IF it's fret buzz, the solution can be simple or difficult. Usually means the neck is not right. Many ways to fix it, but the best way is usually by getting the neck just right. IF it's buzz in the amp from the piezo electric pickup, that's another problem entirely. Could be a loose ground wire, may need shielding, or may simply need to be attached better. Got to see it and hear it to determine what the problem is and the best way to proceed. Contrary to what people think, the neck should not be perfectly straight when under string tension. it actually should be bowed forward, but just a bit. Fret buzz is easiest to fix by raising the bridge. This can be done a number of ways, a shim under it is the quickest and easiest, but only when someone sees it can they tell what way to go. Sometimes, you need a taller nut. Trouble is, these will change the string height all along the neck, and playability sometimes suffers. I've seen them set so high that they were virtually unplayable. Me, I like them as low as possible without fret buzz.
11/5/2019 8:32:05 AM • Alvarez Music • Answered on Nov 05, 2019
Identifying Alvarez AJ60SG-N93 When was this guitar made?
You might try to find out through Google. It may be made in either China or Korea. As long as you quote the number of that model which should be on the inside of the guitar if you look through the hole in the centre of the top of the guitar where the strings run across. Best of luck.
3/12/2019 10:32:41 PM • Alvarez Music • Answered on Mar 12, 2019
2answers
I have a koreain made alvarez model number G2.. value
Hello, Billy -I hope I am correct in thinking you are asking about a guitar.Fixya.com, the website where you posted your question, is intended for asking and answering questions on how to go about REPAIRING THINGS. Providing valuations for anything generally require the appraiser to look at the item in person. Appraisals often depend on the physical qualities of the item in question.I have no idea where you reside. In the USA? If I knew where you lived, I MIGHT be able to direct you to a reliable appraiser of guitars.You may wish to post your question on an online guitar discussion forum. One such forum is The Acoustic Guitar Forum:https://www.acousticguitarforum.com/forums/forumdisplay.php?s=5cdd3989addf3eead2ffd79f960e3c61&f=24You will need to be registered as a member and signed in to post a question.Best wishes.
12/12/2018 8:30:14 PM • Alvarez Music • Answered on Dec 12, 2018
Value and date of Alvarez Guitar
http://alvarezguitars.com/contact/ they are usually more than helpful...
1/27/2018 10:58:04 PM • Alvarez Music • Answered on Jan 27, 2018
What strings do you recommend for an Alvarez MSD1?
Elixir is a really good string. Have a good sound and last longer than any other string I've used. They aren't cheap ~$15 a set.
1/5/2018 5:58:30 AM • Alvarez Music • Answered on Jan 05, 2018
What can I sell my Alvarez 12 string for? model # 5021, serial # 46408
Here's one at Guitar Center for $380. I didn't check Serial #'s. http://www.guitarcenter.com/Alvarez/12-String-Acoustic-Guitars.gc
10/11/2017 4:40:54 PM • Alvarez Music • Answered on Oct 11, 2017
How do I use the built-in tuner (Alvarez System 500) on my Alvarez guitar? I put a new battery in, but nothing happens.
is the battery in correctly? All Volumes up? If yes to both of those and you still get nothing, Then the tuner is not wired into the pick-up or is defective
8/8/2017 12:55:30 AM • Alvarez Music • Answered on Aug 08, 2017
0answers
I looked at an alvarez model # fs130700112 serial # rd260cesb for $60 at pawn shop. what can you tell me about age and value--TY very much!!!
259,http://www.samash.com/rd26cesb-regent-26-series-dreadnought-acoustic-electric-guitar-ard26cesb-p
4/19/2017 1:24:51 AM • Alvarez Music • Answered on Apr 19, 2017
Value of a alvarez yairi 1978 mod dy55
I have a few questions before trying to be precise-Is this supposed to have been handmade by Kauzo Yairi?.Do you have a pic of the guitar?.I got a guitar around '1966-handmade with the writing inside saying something like this-CBS Masterworks handmade by K Yairi ser #... i eventually settled on a price between $5- and $ 7000.00 CDN.That was through an insurance co about a year ago.
4/15/2017 6:00:47 AM • Alvarez Music • Answered on Apr 15, 2017
I'm trying to find the pricing info on an Alvarez acoustic/electric. Model/serial number is AF660ESHB.
That is the model number. It would sell for US$250-350 depending on condition.
1/23/2017 8:25:04 AM • Alvarez Music • Answered on Jan 23, 2017
Alvarez Yairi DY84C Cutaway Rosewood Dreadnought AcousticElectric Guitar Natural Logo
2 questions posted
Top Alvarez Music Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you an Alvarez Music Expert? Answer questions, earn points and help others
View Most Popular
Alvarez Music
  • Alvarez Music
Most Popular Question
alvarez 35666dy46
  • Music
