20 Most Recent
Dell Inspiron 15R Laptop Computer (Intel CORE I3 370M GB4GB) (fndor16b2) PC Notebook Questions & Answers
Opengl driver
Programs that need software such as this usually come with a copy on the disc. If you want the software go to the OpenGL website (it is at version 4.3 now, so you should be able to run it.)
Some programs are not working
Not all software is compatible with 64-bit computers and was probably made as 32-bit. You must buy 64-bit compatible software.
I have a dell inspiron 15R (two weeks old) The
Go to the Dell website and then surf to their Support site. Choose the Download Drivers section of the page. The screen will then ask you to input your Service Tag, which should be on a sticker on the bottom of your laptop. Once you input the number you will get a list of all of the drivers you need for your machine. Download the touchpad driver for you laptop. It would be easiest if you save the file to your desktop. Once the download is finished double click on the icon that was created on your desktop. The driver file will then unpack itself and complete the installation process.
What you should be able to do now is use both your mouse and the touchpad at the same time. Anytime you install a driver for a mouse you will have to reinstall the touchpad driver again. Once you do that they should both be able to co-exist without any further issues.
Thank you for the opportunity to assist you in resolving your issue.
Should you need further information or assistance please do not hesitate
to let us know.
I just bought a new
hi,
It is more likely a software problem.
Since your laptop has still warranty on it, it is the best idea to return it to your dealer and I recommend that also cause doing something on it might forfeit its warranty.
Regards,
John
I am unable to use
Have you made sure that the numlock key is turned on? Just above the number 7 on the keypad is a key labeled Numlk, make sure it is turned on and the keypad should work.
How do you install a hard drive
Larry provides great answer up there ^^^ which is better down here.
Larry Ng Jun 23, 2022
NO PC told (dell has 10000 models)
no OS told, windows what"?
no drive told.
my wild wild guess is the boot drive is locked.
and you are attempting and ******* act. to it.
like deleting key parts of a running OS (windows) (like deleted tires on rims of 85mph moving car, fails)
no real goal told, but the nebular "install HDD"
one can add a 2nd drive easy or any of 1000s of external HDD models or external or internal, SSD or even a thumb drive. (vast) (just 2 steps in fact)
but the boot drive , change out is far far far more complex. and you never not told that.
you want to mess with the C: drive?
now let me guess the real goal (sad I must)
the OS drive windows is failing ( common)
and some lil' bird told you it needs a new boot drive, and then fail to say so here.
okay I will bite.
1: buy a new SSD (hdd fail and are slow)
2: buy a new OS, from MS. or get free w10. (ask how)
3: then put in new SSD,
4: run the w10 installer media (it is free)
5: load w10 to the SSD fresh
6: answer the silly 30 questions it asks.
7: and click activate. (buy it)
How do i change admin password
can;t log in now or what?
what does change mean,
lost it and now can not get in
or means just want to change it , logged in.
NO PC told and NO OS told
or if bios admin or windows admin.
bios or windows.
both are hacking./ if lost.
so google the cure.
How do i eject a cd from the laptop
push the physical cd drive try button marked EJECT
the PC must be running,
or use the paper clip hole trick. (if PC is dead or tray jammed)
google that. clip trick
the dell manuals covers this
