20 Most Recent
Dell Latitude E5410 Laptop Computer (Intel CORE I3 370M 320GB3GB) (bleax4b3) PC Notebook Questions & Answers
The ihdicators show there is audio but it is not audible on my Dell Latitude E5410.
Well there is a bunch of things you could do on this one and I don't want you to overlook the easiest. You can remove the audio driver from the device manager and restart the computer so that it's forced to reinstall itself...make sure you have an internet connection when you restart so that it'll download the software it needs automatically. Make sure the volume is turned all the way up by clicking on the icon in the bottom right corner near the time and sliding it up. Make sure the speakers are not muted. If all else fails, play a music file and hook up headphones to the headphone port. If you hear audio through them, it's not a driver issue, its a problem with the speakers potentially. Good luck with this one! :-)
I want to deactivate the
Usually the mouse control panel has options to disable the pointer or pad.
If you can't see it, download the latest pointer drivers from Dell for your model.
How to fix my dell E4310 from freezing while im using it?
There are a number of reasons that the unit could be freezing up.
- Corrupted file(s)
- Low available disk space
- Viruses and/or malware
- Too many add-ons/toolbars/etc.
- Heat build-up
Number one is the hardest to find. So start with #2. The computer needs free hard drive space to operate. If the disk is nearly full or is very fragmented, this can slow the machine to a crawl. Check for available space and if there is plenty (20GB or more), then check for fragmentation under administrative tools. If the defragmentation tool recommends optimization, allow it to perform it and see if that helps.
For viruses and possible malware, run your virus scanner. It is always a good idea to get a second opinion on such things. Malwarebytes is a free malware scanner that works very well to find adware and some things that many antivirus programs fail to detect.
Many user feel that they have to have every bell and whistle. I've seen some browsers with 7-10 different toolbar add-ons. These almost always come with some adware and always slow down the browser. Uninstall all but the most essential toolbars for the best performance. Heat is a slayer of machines. Laptops are very susceptible to heat issue since they are often placed on beds, sofas, carpets, and yes, even laptop. Many of these units draw cooling air from the bottom and exhaust it to the side. Even those that draw air from the rear and exhaust to the side will often intake large amounts of dust, grit, and lint. These can partially or completely clog the heat sink unit and cause heat buildup of the processor. This will cause the processor to work slower and can actually cause it to thermally lockup, resulting in the need to reboot. Many units can be accessed to clean with a removable cover on the bottom; others may need to be serviced by a technician to clean.
My latitude will not power up. I have a good power
no PC told , at all, model not told
ok generic mode.
1: huge battery inside is bad, shorted remove it , even for ever.
2: run on AC power only now.
3: push power button 10 full seconds release, ,runs now?
4: no, remove all USB devices now. run now?
5: no, coin cell battery dead, , replace it , run nolw
6: no. strip the PC down to find the shorted model.
lap-strip-101
https://www.pcdied.com/Dead_screens/dead-LT.html
Can you hard wire power to laptop?
NO
if you do, a noob will blow it to kingdom come. as in letting the smoke out.
the power-pack does 3 things
it has the correct DC voltage and wattages
and #2 prevents fire when the PC fails and things short inside.
and prevents huge damaging surges landing inside the PC
buy used power pack off fleabay and win.
i bet I'd mow one lawn and and buy one
