20 Most Recent Swatch SVGK407 Watch Questions & Answers
2answers
Swatch GB101. Can I clean inside of the face?
Question edited for clarity. Question moved to maker category. Better to let a jeweler do it, but it you want to try
2/27/2023 6:38:42 PM • Swatch Watches • Answered on Feb 27, 2023
How can i fix my swatch if it is changing the day at 1:30 am instead of 12 am
i'm not sure if your swatch is simply clicking over at 1:30am, or if it is actually starting to switch over much earlier, and then completing the switch at 1:30. the latter is how most watches work...especially my beloved seiko SKX diver automatic. the switchover begins prior to midnight, and ends after midnight...sometimes starting the slow turnover as early as 11:30pm in some watches and ending at as late as 1:30. however, if this is not the case with you, and it's just flipping over late, i don't know what can be done with something like a swatch. you don't mention if it's an automatic or quartz, but literally most swatches are NOT built to be repaired. they were conceived as a throwaway watch when done with, and the cases are not made to be opened for repairs. they have become such a cult item that if you look ******* google you can find companies or people who have learned how to open a swatch without destroying it, can source parts, and can fix/repair the watch. but it's not an easy slam dunk deal. it's different with each model. so, with a timepiece like a swatch, with its unique character of having an endlife, kind of like a replicant from Blade Runner, you will need to likely accept what you have bought with its limitations, and the one you've mentioned is minor compared to the watch just breaking and needing to be thrown out or put in a drawer. the swatch definitely has limits set out by its very concept. and to go back to the movies, as Dirty Harry once said: 'A man's got to know his limitations'. that goes for watches too. cheers.
6/30/2019 6:57:49 PM • Swatch Watches • Answered on Jun 30, 2019
How do I set swatch watch stycs598
Gently pull the middle button, (or 'crown'), outwards away from the side of the watch. It won't move very far but if you do it slowly and gently you should feel it move 2 clicks or 'notches'. Pull to the first 'notch' for the Date settings and the second for the Time settings. For the date twist one way for the day of the week and twist the opposite way for the date number. Pull the crown out to the 2nd 'notch' and you can move the hands to the correct time. Push the crown all the way back In when you have finished doing any of these settings.
11/19/2018 11:33:51 PM • Swatch Watches • Answered on Nov 19, 2018
Hi When can I purch a band for swatch watch YRS421?
call or google a place
11/24/2016 3:24:26 PM • Swatch Watches • Answered on Nov 24, 2016
How to unscrew back without damage
It's made to be about the width of the edge of a coin. Try your smallest coin currency, and work up from there.
3/7/2015 5:52:59 AM • Swatch Watches • Answered on Mar 07, 2015
Calibrate timberland watch
  1. The buttons on your watch have 3 positions: the normal position I will call "A", pulled out once "B", and pulled out twice "C"
  2. Turn the upper button to "COMPASS" and pull it out to the "C" position and select your your declination angle. Declination Angle reference chart: http://lh3.ggpht.com/_XhazifOyjUc/S5VCL88i9GI/AAAAAAAAAF8/kaEksl600tU/image_thumb%5B2%5D.png?imgmax=800
  3. Adjust the upper button to the "B" position and place the watch on a flat surface.
  4. Leaving the watch flat, carefully rotate the watch two full rotations at a rate of 15 seconds per rotation.
  5. Press the upper button to the "A" position.
  6. You're watch's compass is now calibrated.
  7. Always double check the calibration before choosing to depend on it
If you need further help, reach me via phone at https://www.6ya.com/expert/y_7fe7f4854c3d89e6
4/16/2014 5:20:35 PM • Swatch Watches • Answered on Apr 16, 2014
Re: my newly purchased Faux Fox SUOB709 Swatch
wind it forward 12 hours job done
10/14/2013 3:06:06 PM • Swatch Watches • Answered on Oct 14, 2013
2answers
Water (vapor) under the crystal
Water condensation on the inside of your watch crystal means that moisture has entered your watch, most likely through the hole in which the setting crown/stem is fitted, or, possibly, through the door of your battery compartment. It's usually easier for water to enter a watch then to leave it again. Water inside a watch can quickly corrode delicate parts, causing erratic timekeeping and premature failure of the watch, so you'll want to get it out of your watch as quickly as possible.
Fortunately, it's not that difficult to get moisture out of a Swatch. Pull the crown out into the time setting position and remove the back battery hatch. Then, turn the watch face down and leave it in the sun for a few hours. If you're worried about dust and/or rain getting into your watch, leave it inside a parked car that's in the sun--that will actually speed up the drying process, as car interiors, with the windows closed, quickly heat up far beyond outside ambient temperatures (except in winter). If it's dark outside, you can accelerate the drying process by using a hair dryer set to low / medium heat and heating the crystal gently until the moisture has evaporated. You don't want to heat the crystal too much or else it may start to melt or crack.
Once the water is out of the watch, close up the battery compartment and update the time/date for your watch. You should be good to go, as long as you try to keep your watch dry when doing things like washing hands and the like. If you had been doing so, it's also time to stop wearing your watch when you shower, wash your car, or engage in other activities where the watch is exposed to a lot of water.
9/20/2012 10:12:56 PM • Swatch Watches • Answered on Sep 20, 2012
How to set alarm
all different depends on model but you can down load instructions from swatch web site you will need the model and maybe serial number on case back...
3/26/2010 8:59:56 PM • Swatch Watches • Answered on Mar 26, 2010
How to change a swatch beat watch to 12 hour from
Go to the Swatch web site "www.swatch.com"
Select "watches"
Scroll down to "Customer Services", select "manuals"
Select and download the manual for your watch.
1/2/2010 11:00:50 AM • Swatch Watches • Answered on Jan 02, 2010
I have a 2006 SPOT watch that has stopped
did the watch work since the battery was changed
10/8/2009 4:36:47 AM • Swatch Watches • Answered on Oct 08, 2009
Sector adv 1000 manual
ZERO-SETTING OF THE SECONDS-HAND & SUB-SECOND HAND ON THE SECTOR ADV1000 CHRONOGRAPH. NOTE: The pusher buttons A, B & C are positioned on the watch at the 2 o'clock (A), 10 o'clock (B) & 8 o'clock positions (C), while the crown is at the 4 o'clock position. 1) Set the crown at the normal (in) position. 2) Push the B button twice. 3) Pull out the crown to the 2nd position (fully out). a.) Seconds-hand setting: a push of button A moves the 2nd hand by 1 second. Move it until it is at the zero position. b.) 2/100ths second hand: a push of button B moves the 2/100ths second hand by one 2/100ths second. A continuous push moves it quickly. Move it until it is at the zero position. 4) Push the crown back in to normal position. QUICK-SET OF THE CALENDAR DATE With the alarm switch off, pull out the crown halfway to the first "out" position (not fully out). Turn the crown clockwise to quick-set the date. sector adv1000 zero-setting & date instructions-undefined-undefined-0.jpg
4/25/2024 5:30:35 PM • Watches • Answered 9 hours ago
I'de like to have a
Si porque tengo este reloj
4/17/2024 7:04:45 AM • Watches • Answered on Apr 17, 2024
2answers
How do i take my george watch out of 24 hour time?
how do you set the time on the digital george watches?
4/11/2024 7:38:43 AM • Watches • Answered on Apr 11, 2024
My pearl necklace has broken
Contact a local jeweler and see if they do restringing. Most will charge approx $10 per inch.
Thank you for contacting FixYa.
Jewel
4/7/2024 2:26:15 AM • Watches • Answered on Apr 07, 2024
BASE, METAL BEZEL STAINLESS STEEL BACK 10/4312-13 75311 THAILAND MOVT WATER RESISTANT 100F1 QUARTZ
Question edited for clarity. Please don't type in all CAPS, it is considered SHOUTING and is harder to read especially in a jumble of words and numbers. 377, although a maker would be useful! https://www.google.com/search?q=battery+METAL+BEZEL+STAINLESS+STEEL+BACK+10%2F4312-13+75311+THAILAND+MOVT ..
4/6/2024 1:45:42 AM • Watches • Answered on Apr 06, 2024
Swatch SVGK407 Watch Logo
1 questions posted
Top Swatch Watches Experts
ADMIN Andrew
ADMIN Andrew
MegaByteMe
MegaByteMe
Simon Atkinson
Simon Atkinson
Are you a Swatch Watch Expert? Answer questions, earn points and help others
View Most Popular
Swatch Watches
  • Swatch Watches
Most Popular Question
  • Watches
