20 Most Recent
GoVideo Rave-MP ARC5.0 MP3 Player Questions & Answers
Can't find on pc
You should find your MP3 player on your PC as a Removable Disk when you connect it to USB port. sometimes it asks for a driver. If they sold you it without it, actually you don't need it. It should find the driver by itself and stat up.
If you can't see that external or removable dik, yuo got a faoulty produt or you have a bad USB port. Chech if your port is working, change it to another port, but if still nothing, your player has a failure in it's USB outlet. Take it to check for warranty
Rave mp
This means that your unit is defective and is no longer working. The hard drive is bad.
I have bought 3 of these players. All of them worked for a while then had the eventual face/bug on the screen after turning the unit on. When the customer service number DID work, they said that the unit was defective and to return it to the store and get another.
This happened to me, like I mentioned, with 3 different units.
Rave-MP 5.0
There are 2 issues- 1 the keys are locked - unlock and turn machine off.
the other option is to recharge the battery
MP3 player something wrong
Hi Samusv2,
Try removing the battery completely for about 1 minute, then put it back in then try to see if doe shte same thing. Insert another comment on this post and I will respond. Cross your fingers.
Openfit Shokz battery replacement?
Question edited for clarity, typo and CAPS.
Question moved from Cars and Trucks category.
Claim on the warranty irrespective of how long you have had them. They charge $180 but they cost them $20 to buy from China. Package them up and send them tracked and ask them to replace the batteries.
How long is the warranty on AfterShokz?
While we hope you never need it, all new Shokz purchased from authorized retailers come with a two-year warranty that begins on your date of purchase.
Jan 11, 2019
https://www.google.com/search?q=Openfit+Shokz+battery+replacement
My roadking rk4000 wont charge. I turn it off to charge it but there is no indicator light at all, any suggestions?
Are you using the charging cables that came with it? That is a type C. Are you securely attaching the charging cable? A loose connection would keep the battery from charging. If you had a low battery, you would see a red light. That you have no light at all suggests there is no charge left in the battery. I'm not sure the reset will work with no charge which is why you ought to check the cables first.
But turn it off and then hold down the Multifunction button for 10 seconds to reset it. Then turn it back on and see what happens. If you can, test the charging cable on aother device. If you have another type C charging cable, try it, just to eliminate a bad cable. If these suggestions don't work, you may try the manufacturer's customer support.
Can f2100 remote work on my dishtv box?
The F2100 remote is not explicitly listed as compatible with the AerialBox T2100, I recommend using the remote that came with your AerialBox T2100 for optimal functionality. If you have any specific compatibility concerns, I suggest reaching out to Dish TV customer support for further assistance.
Audiosonic CR-06PL not changing time when following manual instructions.
Set Time Hours and Minutes: Press Time/12/24 and Alarm1/ON/OFF buttons at the same time for two seconds and it will start to blink the hour.
Press and hold the button for a fast setting or tap it briefly to increase the setting by one hour. Now set the minutes with time (press and hold) and min.
How do I set the Audiosonic clock? Set current time Press and hold the time button and simultaneously press the hour to set the hours in 24-hour mode .
