20 Most Recent
H&B MP401 MP3 Player Questions & Answers
How do I install music
If your drive has the common tray that extends for loading and removal, look at the bottom of the tray; it will have a depression intended for this small CD format.
If it is slot-loaded, you have a problem. Your best bet then would be to have a friend copy the CD's content to a standard CD your drive can accept.
Puttng films on mp4
Why not have a trial of Video Download Studio to help you with this?
AVI format is not suitable for MP3 player,
so convert the video format is so necessary.
Set MP3 as your output video format with the program.
and then you will get your ideal result.
Get a free trial of VDS from http://www.downloadvideos-convert.com/download-videos-music
Hope it can help you more or less!
I have a Luminox MP4
You need to convert your video format to MP3, so that the video will play on MP3 player.
Video Download Studio can help you with this very well.
Get a free trial from http://www.downloadvideos-convert.com/download-videos-music
My luminox mp4 player is chinese
right turn it on and click the cog then click the screen with the spanner cick the very top sentence of chinese and select english
hope i helped you lee=)
Have a mp3/4 player from china, how do we swap
FIND THE SETTINGS BY BORROWING,BUYING OR WHATEVER A ENGILSH TO CHINESE DICTIONARY AND TRY TO FIND THE LANGUAGE SETTINGS OR JUST FIND A PLUGIN FOR YOUR MP3/4 TO ENABLE ENGLISH LANGUAGE
I can't do nothing but turn on the mp4 and listen
ihgujhb;lhugolieutnqer oiureqibtuqieruntirb ririo terhger ighire hehg jf hajkfjhikfdah kjfdkhkfdjagkfjklajdkflgangj;dfakgjakljfk agndfnakkfjagnfgk;ajfgknfdklghjfdklhjadfhkfdjkhjdkghkfjahkkfldejhkfdnkjgkfkjdk jkj kjkjgkfjhkldfjkhljgkhjgsfkhjakd jk;hjkd hjkjhkdjahkhkjkjukjhlk fdjkhjgdkgjajakjfjlsgkla;fjg; jgkflsja gj klgj;lsakjgkfjlkjgierjgkj;lakf djgklaf kfjlgkakgj l;kjgka;jkgj ajgklajgkfjgkjfgkuijikji87ija8e5uq9450495uoieug9854u0768378657398nb 5683746 b48756w4u akjhgfkdjkadfjgierjkfjgkfd kgjfdijgoierjgkdjfgijajdf jgidfjgkldfj fjdgifdjgkjkalj;kjglkfdjgifoajkfjgieotgjkadfjkfgjdafjijijijijjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjj jirjgioqjgiherg ejigjiejgiaegjiahegihqaeo;rigerhghhgrghggggghhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh hhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh hhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhOIGH OIRWHGLJFHGJHERIUYH GERIHGLJFDGHNFLJDGHA FJGKO J;HG; F HJIHGJADGURHGUY7GY HEAG KAJFKHG J KFDGLKHSDIFGHhgl sgha;ohs ;H LIU hguih A UF GSHUFDHGYYU8ERTUY ghyuihtsiou hshsadf;hjituh;prt
Mp4 player - accidental deletion of software
ok...here goes...
go to "My Computer"
Right-Click the "Removable Disk" icon, and scroll down to "Properties"
click "Properties" and another window will appear. There are Tabs at the top of the window. click the "Tools" tab.
select the "Check Now" function located next to the "Error-Checking" option. ANOTHER window will appear.
select "Automatically fix file system errors" and click "Start".
This takes around 15 seconds and usually fixes the problem. you will then be able to add/delete files in the MP4 player.
I've tried to load stuff onto the mp4 player in
this player will only support mp3 or wma file formats.
avi is a video format and this model does not play video accordind to it's review site.
www.mp3players.alege..net/comments/430/
i hope this helps
Disk Error Message
the best thing to do is RE format the disc. i am currently having the same problem , witch i am tired of fixing them. if the item is from ebay : hong kong , i suggest you tell the buyer and complain. people will do anything for good feedback. saw formatting it will work. but you'll have the same problem in the future. either you copy all your music files to a folder. or buy one from Argos , woolworths etc etc...
MP4 player instructions
To add music
plug mp4 into usp, open ''my computer'' then copy and paste your music into mp4 drive, most likly drive E
to add video
install the mp4 software, then use the conversion tool to convert your video files to amv format then just copy and paste into mp4 drive just as you would with your music files.
Synegy mp4
before uploading it to your synergy, when it is still in your computer, try and edit the pivture and enlarge it using edit. then download it to your synergy.
how did it go? hope this helps.
fixya!
Doesnt do anything,but radio
backup the drive and all folders to your PC.
Then try Formating the Drive. create new folders, i.e music et,c.
** Please note:- The Chinese have very sneaky ways, of making these look bigger in size, than they actually are.
So if you,ve got a 4 gig, and when formatted becomes a 2 Gig.
Thats the true memory storage size.
Try this you guys, good luck.
mike @ Compurepair.
Welsonbel MP4 Player
these are quite simple to work usually self explanatory.
the name probably won,t exist. find system settings, and change the default language to english. it,s a simple matter then of connecting via a usb lead to the pc, and transfering your music across into the designated music folder.
Hint:- make sure you transfer as MPEG3. if it,s only 128mb there,ll not be much room for songs.
Mike @ Compurepair.
How do I change to degree mode on my porpo YH-2000
- Power Off: Turn off the device.
- Jumper Configuration: Locate the jumper labeled "S16" on the device. Initially, it should be connected to pins 2 and 3.
- Power On (Alarm+All LEDs Flashing): Turn the device back on. You'll see the alarm LED and all other LEDs flashing.
- Power Off Again: Turn off the device once more.
- Jumper Adjustment: Change the jumper configuration from pins 2 and 3 to pins 1 and 2.
- Finished: Your Porpo YH-2000 is now set to the desired angular unit mode.
If you encounter any issues, you can press the reset switch on the back of the device to reinitialize it.
Openfit Shokz battery replacement?
Question edited for clarity, typo and CAPS.
Question moved from Cars and Trucks category.
Claim on the warranty irrespective of how long you have had them. They charge $180 but they cost them $20 to buy from China. Package them up and send them tracked and ask them to replace the batteries.
How long is the warranty on AfterShokz?
While we hope you never need it, all new Shokz purchased from authorized retailers come with a two-year warranty that begins on your date of purchase.
Jan 11, 2019
https://www.google.com/search?q=Openfit+Shokz+battery+replacement
