20 Most Recent
Apple Final Cut Pro 5 for Mac Questions & Answers
I want to change the speed of a clip in final cut
Lock the tracks that are below the track your clip is on. This should do it. Keep in mind that adjusting the speed will also make all the clips on your track move in relation to the adjusted speed. If you just want to make the clip change speed without affecting anything else, you can create a new track, drag the clip you want up to the new track, lock all the other tracks and then adjust the speed. Then put the clip back in its place.
How do I start?
the initial of this movie making is in the movie maker.
first learn how to use that properly then you can move towards the
ULead software. checkout the online tutorials, etc. you can move to the
adobe aftereffects by completing the ULead software. you can finally move to the adobe premire for the advance movie making !
thank you
Offline media found, but not being reconnected
In the file picker window (looks like a finder window, says "reconnect" at the top) ... at the bottom of this window it says "Reconnect all files in a Relative Path"
Uncheck this box to make all files available to click on.
Hope that works for you!
Wham Universal DVD "PA Systems for Small Groups" DVD -
www.whamuniversal.com
FCP capture through blackmagic
HI i fear you have multibridge pro
if yes please remove the blackmagic driver abd reinstall the latest one and later it will do a firmware update and should be fixed ,
if not try to connect the multibridge with usb cable and then it will do a firmware update and shold be all normal
worse case if the light in multibride is blinkingnot stable you have problem with the Break out box and should get RMA from Blackmagic and send for repair
Final Cut Torrent
A torrent for this software will lead you to a download of an illicit software.
If you want to use torrent for file sharing only you can find all torrents that you want by using a torrent search engine like bit che.
You can download the software here:
Convivea - Download Bit Che - Torrent SearchDo not use torrent to share licenced software.
Thanks.
Audio tracks
Did you check to see if the hardware in your computer is compatible with that software? Sounds as if you have a sound card that isn't compatible with the software. Check Media player to see if you get sound out of both speakers, if you do then it could be compatibility issue.
Thanks,
Armymason
I dropped my mac lap top and the screen is a bit fuzzy, how can I fix it?
Thank for contacting Fixya, I will be glad to assist you. You cannot, without having a diagnostics performed by a certified Apple technician or Apple Authorized Service Provider. You may have damaged the video graphics card on the main logic board of your MacbookMacbook Pro.Unless you have knowledge on how to go in and physically troubleshoot this geniune hardware issue, I would recommend you do you to your local Apple retail store Genius bar, or Apple Authorized Service center near you and have your Macbook looked at.Just for your reference, I have taken the liberty to provide the store locator links to your local Apple Retail store as well as a general store locator for locating any local Apple Authorized Service center in your area.
Apple Retail Store(Genius bar - need to set appointment via this website link, if planning on visiting Apple store of choice in your immediate area)
Apple Authorized Service ProviderYou don't want to keep turning on the Macbook until you have it checked because it could affect more than just the video graphics card.Regards,-The MacTechTrainer.
I have a Sanyo Xacti 10 MP that records with date and time but when I put the SD card in my Apple laptop and download the videos, the date and time seems to not stay on the videos.
The date and time information may not be embedded in the video file itself, but rather in the metadata of the file. When you transfer the video from your camera to your computer, the metadata may not be transferred along with the video.
To preserve the date and time information on your downloaded videos, you can try the following:
- Use a video player that displays metadata: Some media players, such as VLC media player, allow you to view the metadata of a video file. If the metadata contains the date and time information, you may be able to view it using such a player.
- Transfer the video using a program that preserves metadata: Some file transfer programs, such as Image Capture on Mac, will preserve metadata when transferring files. You may try using such a program to transfer your videos.
- Use a metadata editor to add date and time information: You can try using a metadata editor, such as ExifTool, to add the date and time information to your video files.
It's worth noting that not all video file formats support metadata, so depending on the format of your video files, it may not be possible to preserve the date and time information.
How to factory reset iMac without login or keyboard?
To factory reset an iMac without a login or keyboard, you can try the following steps:
- Boot the iMac in Target Disk Mode: Connect the iMac to another Mac using a Thunderbolt cable. Power on the iMac while holding down the T key. The iMac should appear as an external disk on the other Mac.
- Reinstall macOS: Open the Disk Utility app on the other Mac and select the iMac disk. Choose "Erase" and follow the on-screen instructions to erase the iMac's drive. After erasing, quit Disk Utility and follow the on-screen instructions to reinstall macOS.
- Restore from Time Machine Backup: If you have a Time Machine backup of the iMac, you can restore the backup to the iMac after reinstalling macOS.
If these steps don't work, you may need to seek assistance from an Apple Store or a professional repair service.
I have a new MacMini 2021 Monterrey O/S. I use Zoom but my Gear Head Webcam F#2 4.8mm is not on or is not connecting? IS it compatible with Apple Monterrey O/S?
It's possible that your Gear Head Webcam F#2 4.8mm is not compatible with the new MacMini 2021 running the Monterrey operating system (macOS Monterey).
The best way to check for compatibility is to visit Gear Head website and check for the compatibility list for the webcam with the MacMini 2021 running the Monterrey operating system. If the webcam is not on the list, it's possible that it may not be compatible with the new operating system.
If the webcam is not compatible with the new operating system, it may not be able to connect to the MacMini or be recognized by the Zoom app.
Alternatively, you can try connecting the webcam to the MacMini using a USB-C adapter and see if that resolves the issue.
You may also want to check if there is any new firmware update available for the webcam or the Zoom app that might resolve the issue.
If the issue still persists, it would be best to contact Gear Head customer support for further assistance and check if there is a way to make the webcam compatible with the new operating system or if there is any other solution that can be provided.
