20 Most Recent BFT R93524500001 - Swing Gate Kit, Single, 16-1/2 Ft Questions & Answers
Circuit board showing KO when trying to add new remotes
It means that it has not accepted it ie not compatable or damaged taken too long to do the prcedure or wrong procedure hope this helps
3/7/2016 6:21:04 AM • BFT R93524500001... • Answered on Mar 07, 2016
Why is my circuit board showing KO when trying to add new remotes
It means that it has not programmed your new remote ie not compatable with your system or damaged hope this helps
3/7/2016 6:15:07 AM • BFT R93524500001... • Answered on Mar 07, 2016
2answers
Have a BFT Phobos BT gate opener. The problem I am having is my gate won't close all the way. There is a small gap. I tried to set the limit switch by removing the screw but it isn'
The opener may have been mounted improperly or may have slipped from it's original mounting location. You may not be able to make an adjustment because the arm is already fully extended. You may have to re-position the gate opener. Fixya doesn't do repairs. Posting a question here is like calling the public library for an answer that they can look up.
2/14/2015 6:19:27 AM • BFT R93524500001... • Answered on Feb 14, 2015
2answers
I have acquired a remington model 476 powder
remington model 476 power nailer
3/15/2024 2:11:00 AM • Home Fencing • Answered on Mar 15, 2024
Apollo 1600 actuator arm spins?
Drive way gate (tell what it is first) not a car
2/11/2023 2:52:15 PM • Home Fencing • Answered on Feb 11, 2023
Elite SL3000 opens, buts does not close. amps rise on when trying to close, and will close when i push on it a liitle. thanks G
It sounds like there may be an issue with the opener mechanism on your Elite SL3000 fence gate. The fact that the gate opens but does not close, and that the amps rise when trying to close, suggest that there may be a problem with the motor or gear assembly. Additionally, the fact that the gate closes when you push on it a little suggests that there might be a problem with the alignment of the gate or with the gate's track. Possible causes for this issue include a faulty opener motor, a problem with the gear assembly, or a problem with the alignment of the gate. Here are some steps you can try to fix the problem:
  1. Check the alignment of the gate: Make sure that the gate is properly aligned with the gate post and that the hinges are not bent.
  2. Check the gate's track: Make sure that the gate's track is clear of any debris and that the rollers are not worn out.
  3. Check the opener motor: Make sure that the opener motor is functioning properly and that the gear assembly is not stripped.
  4. Check the battery: Make sure the battery that is powering the opener is charged and in good condition.
  5. Check the settings: Make sure that the gate opener settings are correct and that the gate is set to close automatically.
If you are not comfortable with these steps or the problem persists, it's best to contact Elite customer service or a fence/gate professional for further assistance.
1/23/2023 10:19:24 AM • Home Fencing • Answered on Jan 23, 2023
4answers
Where can I find a wooden automatic gate?
A wooden driveway gate needs to be supplemented with a steel frame to last since they will be opened much more frequently than an ordinary wood gate. The slide type gates will need the structural strength to resist the pulling of the chain. A swing gate, will be cantilevered since a wheel at the opposite end will trigger the obstruction reversing mechanism in the gate operator. This cantilevering over the long width of a driveway requires steel in the structure both to prevent sagging and to keep the gate looking good over time. Gaps and misalignment will occur naturally as the wood shrinks and expands in weather. The steel frame helps to hold everything together tightly. We make our gates using wood cladding over a steel frame. If you like check out our link at the bottom for more information. Here are some projects we have completed. find-wooden-automatic-gate-jz4xvwekbchaveh105aozslf-1-0.jpg find-wooden-automatic-gate-jz4xvwekbchaveh105aozslf-1-1.jpg find-wooden-automatic-gate-jz4xvwekbchaveh105aozslf-1-3.jpg find-wooden-automatic-gate-jz4xvwekbchaveh105aozslf-1-6.jpg http://aaagate.com/wood-iron-gates find-wooden-automatic-gate-jz4xvwekbchaveh105aozslf-1-10.jpg find-wooden-automatic-gate-jz4xvwekbchaveh105aozslf-1-15.jpg find-wooden-automatic-gate-jz4xvwekbchaveh105aozslf-1-21.jpg find-wooden-automatic-gate-jz4xvwekbchaveh105aozslf-1-28.jpg
12/29/2022 5:25:48 AM • Home Fencing • Answered on Dec 29, 2022
2answers
The remote of my Centurion D5 gate motor is opening the gate but not closing it. What can I do to rectify this?
We help managers make the right hiring decision consistently to ensure their companies continue to thrive, staffed with the best men and women for the job. We are the world's primary choice in pre-employment Integrity testing. Read more: Pre employment integrity test
10/13/2022 3:32:00 AM • Home Fencing • Answered on Oct 13, 2022
5answers
How I can fix energy bills of my home?
High energy bills is a very common problem. Every home owner or tenant wish to save energy to lower energy home energy bills. There are different ways to lower your home energy bills. I am going to share a blog post which will guide you to do it properly.
9/29/2022 7:06:32 PM • Home Fencing • Answered on Sep 29, 2022
2answers
Ramset RAm-100 gate opener. Why doesn't gate open?
BAD MOTOR PERHAPS
5/26/2022 11:20:55 AM • Home Fencing • Answered on May 26, 2022
I have a DTS gate motor that opens everytime there is a strong lightning storm in the area. please give advice
Shield the control box with Aluminum or lead foil to cut out EMI.
2/15/2022 10:52:42 AM • Home Fencing • Answered on Feb 15, 2022
3answers
What is the best fence I can use for my dog?
First, try to get a fence made from a durable material like aluminum or a wire fence. Of course you will compromise the looks...don't get a wooden fence unless it is more expensive since big dogs tend to ruin them
12/3/2021 3:05:19 AM • Home Fencing • Answered on Dec 03, 2021
Led lights that glow when power is off?
I think you should hire a competent electrician. your question indicates you aren't qualified or competent to work on electric power, and it could cause a fire.
11/6/2021 5:11:04 PM • Home Fencing • Answered on Nov 06, 2021
2answers
The centurion gate motor open by itself how can I fix that problem please
Do you have sensors that stop the gate closing on people or cars ? If so put your ear near the sensor but not inline with the opposite one. Now gently wave your hand in front of it .... if there is no click then something is obstructing the beam. Sometimes spiders get inside and spin that candy floss type web in there .
9/13/2021 11:52:46 AM • Home Fencing • Answered on Sep 13, 2021
Master code on liftmaster TAC1/TAC2
Contact Liftmaster directly to request the master code.
7/20/2021 4:59:22 PM • Home Fencing • Answered on Jul 20, 2021
Just hooked up exit wand to Mighty Mule 360, gate keeps opening and closing randomly.
The timing relay has to be setted right. There is a time control on every unit,. 1-[Distance has to be set right before setting time relay] 2-(opening time and closing time has to be set accordingly to ur safety and wanting)
3/27/2019 7:05:27 PM • Home Fencing • Answered on Mar 27, 2019
I am having trouble with my Elite CSW-200-UL gate on my driveway. It has randomly been responding to the remotes and then I had to punch in the code to make it work. Now it is not responding.
The first place to look is your receiver. This is the device, often separate from the actual gate operator, that responds to your transmitter. Stand next to the gate operator and you should hear a small click coming from the receiver when you or someone else pushes the button. You can sometimes find the receiver by following the antenna cable back to it. If it does not have an external antenna, look inside the operator box for either an antenna screwed into the receiver or a wire hanging from a plastic box. If you hear the click and the gate does not open, the possibilities grow exponentially so we won't try to address every possibility here. If you hear a click when you are close, but not when the transmitter is triggered at a distance, check the antenna. If you don't hear the click, then either the remote has lost programming (this often happens with rolling codes transmitters when they are not used for a long time), or the receiver is not working. Check to make sure the receiver is getting plenty of power power using a meter. It should read at the recommended voltage or a bit higher. Usually around 24 volts but some receivers can work down to 12 volts. If it gets plenty of power and the remotes have been programmed back in, consider replacing the receiver.
3/8/2019 12:26:58 AM • Home Fencing • Answered on Mar 08, 2019
I really need a lazy susan,if anyone has got it,please help me out
you can find one via the internet. doh.
10/19/2018 12:42:29 AM • Home Fencing • Answered on Oct 19, 2018
What can i use to get rid of my warts under my feet
duct tape.
10/19/2018 12:39:41 AM • Home Fencing • Answered on Oct 19, 2018
BFT R93524500001 - Swing Gate Kit, Single, 16-1/2 Ft Logo
3 questions posted
Top BFT Home Fencing Experts
ADMIN Andrew
ADMIN Andrew
ADEL AUTO DOORS
ADEL AUTO DOORS
Level 1 Expert
Yarik Bess
Yarik Bess
Are you a BFT Home Fencing Expert? Answer questions, earn points and help others
View Most Popular
BFT Home Fencing
  • BFT Home Fencing
Most Popular Question
bft phobos bt gate opener problem am
  • Home Fencing
