20 Most Recent Hitachi Director's Series 65XWX20B 65" Rear Projection Television Questions & Answers
0answers
2answers
No Picture
Did you have color problems in past? Most of these sets have convergence problems. Amps goes out. But you should have seen some type of distortion from color, red,blue, green. If no color problems then maybe vertical ouput out or horizontal output bad.
2/24/2013 9:30:41 PM • Hitachi... • Answered on Feb 24, 2013
Blue power light flashing and
You have problem with y sus on tv. Please fix it or replace with new one.
Regards
2/1/2011 5:17:28 PM • Hitachi... • Answered on Feb 01, 2011
I have red wavy lines
jonesey 1019,
It sounds like you have a bad convergence circuit. This is common with CRT based TVs after some time. The driver ICs which correct the beams to align them run very hot and dry out the heat sink compound. This makes the IC heat up and fail causing the problem that you have. The solution is to replace the ICs. I have a tip at http://www.fixya.com/support/r4220499-change_projection_tv_convergence_ics which explains the process, where to get the parts at the best price and how to accomplish the repair.
Thanks for using FixYa and for the great rating.
hardrocko
11/30/2010 9:10:14 PM • Hitachi... • Answered on Nov 30, 2010
65XWX20 B WILL NOT STAY ON THE LIGHT GOES ON FOR A
pwer board malfunctioning
5/22/2010 4:35:01 PM • Hitachi... • Answered on May 22, 2010
My tv was hit by a power surge and wont turn on
Power board bad
5/22/2010 4:32:01 PM • Hitachi... • Answered on May 22, 2010
Not able to adjust red convergence on top or bottom
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
4/3/2010 9:44:52 PM • Hitachi... • Answered on Apr 03, 2010
Can't set red convergence on 65" Hitachi
Projection TV sets have several common problems listed below.
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
Example Photo:
You can see more examples and find a fix here...
3/25/2010 5:09:09 AM • Hitachi... • Answered on Mar 25, 2010
My 6 year old 65xwx20b tv convergence problem
Good Day,
This is a common problem with this TV, but there is an upgrade to correct the CONVERVGENCE circuit problem.
If you want to repair this concern yourself: Contact: B&D ENTERPRISES,
1-800-458-6053, www.bdent.com and ask for KIT10 for your Hitachi TV.
If you want some else to do the repair for you call an Authorized Service Center.
Needs convergence IC's
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Good Luck,BIG IRISH.
11/23/2009 9:41:31 PM • Hitachi... • Answered on Nov 23, 2009
Can't get manual conf. to hold in white
Ur convergence it dead.need it to be replaced,know how to solders?Tries these Websites for convergence kit.Tv repair World.com or Tv repair Kits.
11/18/2009 7:30:24 PM • Hitachi... • Answered on Nov 18, 2009
NEED TO NO IF ITS WORTH IT
I fixed mine myself for under 75.00!!! To me it was worth it. I could not afford a new one. Plus the newer LCD/Plasma sets fail in 3-5 years anyway. I bought a complete kit from the folks at www.TvRepairKits.com
8/19/2009 2:07:48 AM • Hitachi... • Answered on Aug 19, 2009
HITACHI 65XWX20B - How to disassemble the cabinet?
The 65XWX20B comes apart in 2 pieces - there is a top half and a bottom half.
- The bottom half houses all of the electronics, projection lenses, etc. It is very heavy and should be moved with care.
- The top half is basically just the screen.
I have moved this Television multiple times, even up and down from a 3rd floor apartment!
- First remove the screws holding the top and the bottom, the important ones are on the sides of the TV.
- This is important, I suggest 3 people do this part: Slowly lift the top away from the bottom half of the TV, but -not- very far. There is small wiring harness that that attaches the top of the TV to the bottom to a circuit board. This must be unplugged by one person while the other 2 hold the top half of the TV slightly above the bottom half. Note carefully where this plugs in so that you can reassemble easily.
- Once this is disconnected the TV is much easier to move, although still quite heavy and bulky. Do not turn the TV on its side - keep it upright while moving.
Reverse this process to put it back together.
Once you have done it once it is quite easy.
Good luck.
11/24/2008 4:05:08 AM • Hitachi... • Answered on Nov 24, 2008
Loss of Green Color
Check the green Crt PCB circuit for bad solder if the solder looks good check the green drive transistor located on that same PCB.
Let me know if you need further assistance.
6/30/2008 8:15:09 PM • Hitachi... • Answered on Jun 30, 2008
2answers
Picture distorts randomly and resolves by turning off and back on
Well its probably gonna hurt your feelings and your wallet because its gonna be a powerboard problem which will cost a pretty penny or your lamp which will cost around $200. Try and take it in to a serviceman and itll be around 60-70 bucks just to look at it. HOW MUCH DO YOU LOVE YOUR TV? remember people need parts too. you could make some money on ebay for the parts if you decide to hit up the sale.
8/10/2007 5:55:16 AM • Hitachi... • Answered on Aug 10, 2007
Hitachi tv shuts off . When I turn on the TV iMessage says please wait then turns off two seconds later.
That sounds like it is not booting properly. I would check for correct power supply opperation and if not that, look for a software reloading procedure in the user instruction manual.
2/11/2024 9:04:18 AM • Hitachi... • Answered on Feb 11, 2024
HI MY NAME IS MAZEN FAHMY I haVE DIODE T3D 36 THIS ZENER & DIODE 2 AND THIS IS IN DATA SHOW HITACHI CP-X3030WN FIX POWER.
https://www.google.com/search?q=DIODE+T3D+36 https://www.google.com/search?q=HITACHI+CP-X3030WN
Original Projector Ballast Main Power Supply For Hitachi ...
AliExpress https://www.aliexpress.com > item Original Projector Ballast Main Power Supply For Hitachi CP-X3030WN. 1/1. 1. US $52.62. Price shown before tax. Free shipping?Free returns. Original Projector ... US$52.62
Projector Power supply For CP-X2530WN CP-X3030WN ...
AliExpress https://m.aliexpress.com > item Projector Lamp Ballast And Power Supply For Hitachi CP-X2530WN. US $80. Projector Lamp Ballast And Power Supply For Hitachi CP-X2530WN. EUC 215g N/T05 ... US$50.00
CP-X2530WN/CP-X3030WN CP-WX3030WN
Projector Central https://www.projectorcentral.com > pdf > projecto... power supply make the projector turn on. Setting up. ?This product is also designed for IT power systems with a phase-to- phase voltage of 220 to 240 V ... 118 pages ....
12/5/2023 2:26:21 AM • Hitachi... • Answered on Dec 05, 2023
Change input on Hitachi LCD TV model LE65K6R9 without remote?
I'd unplug/disconnect the Roku and after 30 seconds try the control button on the back. If you can change the input do so, then plug the Roku back in. Until you use the input button on the back to change input to Roku, you should be able to use the other buttons on the back to control the TV. If this does not work, unplug both the TV and the Roku. Wait maybe a minute, then plug the TV back in and follow the above instructions. Here are other alternatives: Using physical buttons: You can find the physical buttons on the left or right back side of the Hitachi TV. Using these keys, you can change the input, adjust the volume, or turn on Hitachi TV without a remote. Press the Input button located at the back or side of the Hitachi TV. The list of connected sources will appear on the TV screen12. Using external devices: Connect a wireless keyboard or mouse to your Hitachi TV and change the input1. Buy a universal remote: You can buy a universal remote to control your Hitachi TV and change the source.
10/13/2023 9:21:56 PM • Hitachi... • Answered on Oct 13, 2023
How to remove small popup bottom left of Hitachi smart tv screen.
A little popup that appears in the lower left corner of your Hitachi smart TV screen may be related to one of the TV's settings or capabilities. You can attempt the following actions to get rid of it: 1.Investigate notifications: Smart TVs occasionally show notifications for different events or upgrades. If there are any notifications, look for them and then clear them by following the on-screen directions. 2.Applications and Inputs: Make sure all programmes and inputs are closed. The popup may occasionally be connected to an input source or app, which can be closed to get rid of it. 3.On-Screen Display (OSD) Off: There might be an OSD option in the settings menu on Hitachi TVs. Try disabling OSD or changing its settings to see if it gets rid of the popup. Verify any software/firmware updates: 4.Make that the most recent firmware or software upgrades are installed on your TV. Pop-up windows may appear as a result of faults in outdated software. Look for a software update option in the TV's settings menu. 5.Firmware Reset: You can conduct a factory reset on your TV if the problem persists after you've tried various troubleshooting measures. The default values for all settings will be restored as a result. Make cautious to back up any crucial data before doing a factory reset because doing so will also remove any customised settings and data. 6.Message Hitachi Support here: If none of the aforementioned fixes the problem, it's a good idea to get in touch with Hitachi customer service or refer to the TV's user manual for detailed instructions on how to get rid of the popup. Regarding External Devices: 7.The popup may be related to any external devices you have connected to your TV, like a cable box or game console. Make sure that these gadgets are operating properly and that the settings have been changed as necessary. Keep in mind that depending on the type and software version of your Hitachi smart TV, the precise processes and options may change. For instructions unique to your TV model, consult the user manual, or go to the Hitachi website for further help options.
9/30/2023 6:30:41 PM • Hitachi... • Answered on Sep 30, 2023
Hitachi LE42S704 none of the HDMI ports work, need to update (i think)
Are you getting the various HDMI inputs on the screen but it acts like nothing is connected? We have repaired hundreds of TV's with no HDMI signal over the years and have never had an update correct this issue. There is an IC close to the HDMI input jacks (U501) that decodes the data, that's always been the defective part. You can order the part and change it but you will need advanced soldering skills and the equipment to do it, I'd recommend replacing the main board if you can find one.
5/23/2023 4:18:27 AM • Hitachi... • Answered on May 23, 2023
Hitachi Director's Series 65XWX20B 65" Rear Projection Television Logo
Popular Tags
26 questions posted
Top Hitachi Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Hitachi Televison & Video
Most Popular Question
hitachi 65xwx20b disassemble cabinet
  • Televison & Video
