20 Most Recent
Hitachi 53SDX01B 53" Rear Projection Television Questions & Answers
Picture quality is really dark, have cleaned everything, still doesn't work
Presuming you cleaned the lens and the mirror you may have a problem in (yes) the power supply---some of these develop an issue where the filament voltage for the 3 picture tubes goes down as a resistor in the supply from age goes UP in resistance---going to need a meter and a service manual to find that.If that is beyond you then consider getting a tech or a shop to look at the set.Let me know if you have questions.
Crt coolant kit
Replacing the coolant is not going to help a dark picture and is not for a do it yourself repair---it is toxic and dangerous to replace unless qualified.
Picture quality is very dark.
Well, that explains a lot----mirror or the lens or even the screen may be coated with grime-----be careful if you attempt to clean that screen, easy to damage and expensive to replace--what about the mirror and the 3 lens?
Hitachi 53SDX01B sound
This set had lots of audio problems- some idiot decided to put the entire audio circuit on a single compact board---it develops all kinds of bad solder connections on the numerous flat Pak chips on both top and bottom of the board.Board no longer available from Hitachi (srs board) and rebuild usually is over 150 plus shipping.We send the board out for that as I have seen top notch experts spend hours trying to solder the board and not after have a working set.Hitachi just crammed too many parts in too small an area and the heat bakes the board---Understand I was seeing this failure when these sets first came out--failing after a week or two in someones home.
Picture has gotten darker over
Your TV most likely has one or more possible problems. Problem #1: Convergence Chip Failure ( common problem )Here are some of the most common symptoms and example photos of a convergence problem
- Screen looks 3D
- Colors don't line up
- One or more colors can't be adjusted when using the convergence menu.
- Screen is bowed or warped.
Here is a quick test....Using your original remote go-to the tv settings then goto the convergence section.Try to adjust the red and then the blue convergence.You should be able to move them up, down, left, and right.If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem. Solution #1You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc. Problem #2 CRT Fluid is CloudyProjection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos aroundimages. Picture of a set that needs the fluid changed. TV set after fluid change Solution #2What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
I need to replace the dust cover on my Hitachi 53SDX01B
the problem here is Hitachi usually if it still has it sells all three screens as a unit---expensive.You may want to search with GOOGLE the internet as some companies sell replacement "protective" screen replacements.I have even seen one time someone found a piece of plexi-glass and had it cut to the exact size and thickness for a replacement.
I need a mirror for a hitachi 53sdx01b
Hitachi USA or Andrews Electronics in California who ships all over and is the largest OEM parts dealer in the USA.You can also Google the brand/model number with replace mirror after it as there are some vendors on the internet who sell replacement mirrors.let me know if you have questions as I am here to help you.
I have a Hitachi 53SDX01B.
Hello criticalcelt,
First press the menu button on the television, if it pops up the menu list, then it means the cable is faulty. Try to hook up your television to dvd player to confirm if the picture will come on, if it does, that confirms it that it is the cable that is faulty.
But if the test shows it is not the cable, then it means the t-con board of the television is bad and need to be replaced. Also check the Y and Z sus.
Replacing the t-con board will definitely solve the problem for you.
All the best.
Elect_Comp
Magic Focus button will not line up picture. Red
The tv have a problems known as a convergence picture problems it is dead.The tv have any colors lines like R,G,B mis alignments,tv have any colors shadows pictures or 3D pictures look alike?Yes,than the tv convergence board it is dead and the causes of these problems.The tv convergence board must have to repair like replacing like 2 STk covergence ICS and some or all of it resistors too.To fixed the tv convegence board to solved the tv convergence picture problems.The tvs shops will cost u like $300-350 for parts and labors.
The color looks red and the picture is not clear.
This problem is very common with rear projection TV's.
It
is related to one or more of the colour guns being out of alignment or needing to be replaced.
The only way to correct this issue is to have a technician come in and
fix it or bring it into a repair center. I personally would suggest
purchasing a new TV. The cost of getting them aligned is usually more
then a basic LCD.
The original MSRP was 4100 I believe.
Hope this helps
Dustin
I have an Hitachi 53sdx01B rear projection HD TV.
The tv have picture look like a bright dull hallow glow to the screen,yes,than the tv CRT tubes coolant chemicals is bad.Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a coolant kit to do the replacement.
