20 Most Recent
Apple Mac OS X Server for Mac Questions & Answers
I was using apple laptop
You should never format a hard drive without first figuring out if you can rescue it with recovery software. If it has a recovery program on disc or flash ..you will have to switch the bios to boot from one of the drives and reload with the recovery disc or flashdrive. It may also has a hidden partition which will allow you to run in safemode to fix the probelm.
Start up my mac and it keeps giving me a flashing
It may be that the harddrive is not set as the boot device any longer.
Follow these steps:
- Turn on, or restart, your Mac.
- Immediately press and hold the Option key. After a few seconds, the Startup Manager should appear. The Startup Manager scans for available available volumes.
- Use the left and right arrow keys on the keyboard to select the volume you would like to use.
- Press the Return key on your keyboard to start up the computer from the volume you selected. Because this change is temporaryyou will need to set the default startup volume for your Mac after your computer is running, open "System Preferences" and choose "Startup Disk" from the "View" menu. (If this does not resolve this issue please messageme again)
Is there any free updates for my mac 10.5
Apple stopped supporting OS X 10.5. Upgrades are only $20 to 10.7.
If your Mac has 10.5, Lion, 10.7, is probably as high as you can upgrade. I would check either eBay or Amazon, as I've seen Lion disk sets selling for less than $5, then $4.95 shipping (or less on eBay).
All the best to you,
Kerry Hostetter
10/9/2018 5:19:12 AM •
Apple OS...
Answered
on Oct 09, 2018
Need advise on slow running Mavericks?
Did you check hard drive space? You drive may be running out of much needed free spaces. You can check by About This Mac through Apple Logo. Also I would recommend to run Disk Utility Verify/Repair disk in order to fix any error on the drive. You should download Stellar Speedup Mac software to clean & optimise Mac hard drive for free. You can remove plenty of junk data from the startup drive. You can download from here -
Stellar SpeedUp Mac
Try to keep at least 25% of hard drive free for OS X operations.
10/17/2014 6:23:15 AM •
Apple OS...
Answered
on Oct 17, 2014
Update 10.58 to 10.68
must use system disc. Cannot upgrade across platforms. must use 10.6 disc then update software from there. There is no way to go from 10.5 to 10.6 without installing 10.6 from disk
7/25/2014 10:41:05 PM •
Apple OS...
Answered
on Jul 25, 2014
How do i update from 10.5 to 10.6
you need system disc, cannot upgrade os with update software. Must have system disc to upgrade to next OS.
Can get 10.6 from apple or ebay or amazon or maybe someone on craigslist.
7/25/2014 10:18:45 PM •
Apple OS...
Answered
on Jul 25, 2014
Powerbook G4 12" 1.5 Aluminum will not boot.
try booting with disk select option.
hold down option key and power up. Try resetting pram.
Look up key commands on apple support.
Try safe boot with holding down s key
etc....
7/25/2014 10:16:14 PM •
Apple OS...
Answered
on Jul 25, 2014
Trying to download mac os x on my macbook 2007
cannot dl full version. Only updates. If you have 10.4 and want 10.4.11 you can dl it no problem. If you have 10.4 and want to go to 10.5 or 10.6 you need system disk.
10.5 and earlier not available from apple.
can be found on ebay and amazon and craigslist.
10.6 and up available on apple.com
7/25/2014 10:12:32 PM •
Apple OS...
Answered
on Jul 25, 2014
Free download for OS X leopard
no such thing. Only updates. No full version online for download. Apple polices that stuff. THey give free updates to exisiting os systems.
7/25/2014 10:10:27 PM •
Apple OS...
Answered
on Jul 25, 2014
Download free mac os x 10.5.0 full version
nope. ebay. can only download updates or upgrades within OS. Not full system. Check for yourself and see if you can find 10.6 full download or 10.7 or 10.8 or anything. Only find updates. No full OS dl online.
Amazon or craigslist or ebay best bet
7/25/2014 10:04:10 PM •
Apple OS...
Answered
on Jul 25, 2014
