20 Most Recent Canon FAXPHONE L80 Laser Questions & Answers
When sending a fax on the faxphone L80 it pulls in duplicate page
There is a little rubber pad where original feed in. Look at it on edge and you'll see it has concave wear. Carefully remove black plastic hold down and flip rubber pad over. You'll have to make a new hole so it will lay flat.
11/7/2018 4:39:56 PM • Canon FAXPHONE... • Answered on Nov 07, 2018
4answers
Fax does not know paper is loaded. says load paper
When you load your paper, you must press the Stop/Reset button for it to reconize you have loaded paper.
5/14/2018 9:41:20 PM • Canon FAXPHONE... • Answered on May 14, 2018
2answers
Fax can fax out but cannot receive
What do you mean by "cannot receive"?
Can't you even start receiving manually? When someone rings, pick up the hanset and press START button - it should start receiving. Of course no document should be present in the input tray, otherwise it will start sending.
If you can receive manually, then all you have to do is to change the receiving mode between "Auto", "Fax/Tel" or "Fax", to get automatic pickup and receiving.
1/17/2017 6:27:39 AM • Canon FAXPHONE... • Answered on Jan 17, 2017
What is the best plasma cutting machine
we dont rate consumer products --look up under consumer reports for review and guides of the different units
9/14/2016 12:33:02 PM • Canon FAXPHONE... • Answered on Sep 14, 2016
0answers
Canon L80
Be the first to answer 7/4/2014 3:05:40 AM • Canon FAXPHONE... • Posted on Jul 04, 2014Be the first to answer
2answers
Every fax we try to send it comes up with a error
Hello.
NG means: Some or no pages sent.
Check the paper feeder to see if the page is pulling through.
Listen to see if the fax line "sounds"like it is working or if you hear dialing or not.
Hope this helps.
6/5/2014 2:10:09 PM • Canon FAXPHONE... • Answered on Jun 05, 2014
What is ecm tx
ECM is basically error correction mode. Tx is transmission. If you're having trouble transmitting, lower the default speed to 14.4kps. Fax transmit best on analog phone lines. Digital lines will work, but unless you have a digital fax modem 14.4 is often the best you can hope for. If you're on a voice over ip max speed is 9600bps and it probably still won't work. Buy an analog phone adapter for VoIP. If you're still having transmission troubles turn off ECM.
5/4/2014 1:06:47 AM • Canon FAXPHONE... • Answered on May 04, 2014
0answers
manual
Canon FAXPHONE L80 Laser Logo
282 questions posted
old marine
old marine
ZJ Limited
ZJ Limited
View Most Popular
  • Canon Office Equipment & Supplies
Most Popular Question
error message install toner cartridge
  • Office Equipment & Supplies
