20 Most Recent
Canon imageRUNNER 8500 Copier Questions & Answers
E000532-8001
i just replace Stapler shift motor GEAR..its work!!
12/12/2019 8:16:55 AM •
Canon...
Answered
on Dec 12, 2019
Canon iR8500 with Error E000583-0001
Hello Jeremy,
This error code has to do with your finisher. The auxillary tray is not finding its home position or does not leave the home position within the alotted time. Check for binds. I have limited exposure to the K4/3 finisher but try this. Turn the copier off, and open one of the finisher doors. Now turn the copier back on with the finisher door open so it cannot initialize. Once the copier is basically ready except the finisher door is open, close the finisher door and observe all the **** (and theres alot) initialize. This may help determine the problem. I hope this helps...........................SPINAL
6/27/2019 1:12:16 PM •
Canon...
Answered
on Jun 27, 2019
Error E354-0002 ir 8500
Error E354 in Canon iR 2016error e354 code appear when you replace PCB controller board.Please note. Before replace your PCB board with other one.Pull out a small (FRAM COUNTER) chip from your old PCB board you can found it right side of the PCB board near a battery cell the chip attached with screw open screw and pull it out and attached it with your new PCB board .install your PCB board in the machine and turn on power error e354 will go off.
5/5/2019 5:44:01 PM •
Canon...
Answered
on May 05, 2019
E602
Turn on holding down 1 and 9 keys. will go through a long complete format. If blocks do not fall down through screen left to right, HDD is completely gone.
8/31/2018 12:53:26 PM •
Canon...
Answered
on Aug 31, 2018
E243
Main controller PCB
1) Turn offf and then on the power switch. Is the problem corrected?
YES: End.
NO: Replace the Main controller PCB.
Control panel PCB
2) Try replacing the control panel PCB. Is the problem corrected?
YES: End.
2/16/2017 4:48:55 AM •
Canon...
Answered
on Feb 16, 2017
Canon IR6000 shows error code E000061-0001
A E00061-0001 deals with the drum charge is missing. I would look to see if the primary charge unit is installed correctly, if so I would pull the unit out and make sure none of the corona wires are broken.. could be one of the post wires or the grid is broken. You may also, have a end block that is arching out. If you are not a service tech, you will need to call one to repair the code. It can't be cleared till it is fixed... Good Luck
7/15/2015 4:19:02 AM •
Canon...
Answered
on Jul 15, 2015
Ir 85 error code E000015-0000
hello
8500 IR copy machine
E00015 - 0000 errors.
Please guide me.
I also translated by the site you have to translate the sentences. So you have the goodness wording is easy.
Thanks
1/26/2015 10:01:55 AM •
Canon...
Answered
on Jan 26, 2015
E0061 canon 1100
Primary charge failure .broken wire or not seated or arching to the grid.
1/6/2015 7:04:59 AM •
Canon...
Answered
on Jan 06, 2015
How to fix Error Code E000732-001
Check the connection from Fiery to reader controller PCB, located on the left side of the machine, just beside the TCP /IP port connection.
8/10/2014 3:25:21 PM •
Canon...
Answered
on Aug 10, 2014
