20 Most Recent
Dymo LetraTAG Thermal Label Printer Questions & Answers
My Dymo LetraTag will not
I have the same problem with my printer. New batteries no corrosion not used very much and will not turn on. Did you ever find an answer that worked?
My dymo letratag prints only
Your cassette tape has probably become unthread. Take the cassette out of your handheld printer. Make sure that the tape is fed under both claws on each side of the tape. If the tape is only under one claw, your label will not be flat and will only print the bottom half of the letter on your label.
Tape Jam
There may be a small piece of label cutting stuck in the gears.
remove the label cartredge, you will see a white gear set between the pinch wheel and the print head. Use a micro drive or something strong and give the gears a little help while pushing the print button. You may have to do this several times. Be careful not to use too much force as this may knock a tooth off. Good luck.
My Dymo continues to print prefet labels.
My Dymo LetraTag won't print anything. What is
Yep, same thing happened to ours. It would reel the label tape through and sound as if it were printing but nothing would show up. We replaced the batteries and it works perfectly again.
Dymo Letratag Flashing Screen
I did this
https://refreshcartridges.co.uk/igloo/reset-dymo-letratag-printer/
I shuffled the batteries round
Then reset it (see above link and YouTube video on that web site)
Then put Duracel 2400 mAh rechargeable batteries in and it worked perfectly again!
Error 1 dymo letra tag xr
Hola,cambiale las pilas,o mira haber si se ha atrancado.Esas son las 2 soluciones para el error 1.
Un saludo.
