20 Most Recent
JVC KD-AVX1 Car DVD Player Questions & Answers
Dvd player
There may be dirt on the laser lens. Maybe there is something mechanicaly worn that is causing the laser to not properly track the DVD information on the disk.
How to clean a DVD lense from eHow:
http://www.ehow.com/how_2036275_clean-lens-dvd.html
After cleaning the DVD lens, if the problem still exists, then the DVD player will require proper service. If it is a low to medium cost unit, or if it is more than about 3 to 4 years old, then it may not be worth to service.
Jerry G.
JVC KD-AVX1 parking break
your car probably wont have one this wire is designed to be hooked to the park brake switch wire so you cannot watch movies going down road.as this is illegal. the wire gorunds when park brake is pressed. splice it into the wire on brake
I have a JVC EXAD
You can get a new face from pacparts.com, but it is about $330. You'd be better off getting a new deck.
JVC KD-AVX1. The head unit
is this a headunit you have just installed? if not then I am not sure, but if it is, try swapping the red and yellow wires over. One should have permanent live, the other should be switchable. (unless you want the headunit to stay on when the ignition is off, in which case put them both to a permenant live feed.)
Hope this helps.
I just installed one of these, and the FM radio
It sounds like you are running your audio through an amplifier. If so, you are probably using the blue wire (antenna remote turn on) instead of the blue/white (amplifier remote turn on). The blue wire turns off when leaving tuner mode.
LOOKING FOR THE WIRING HARNESS
You can download the complete installation and connections manual in PDF format by clicking this
link.
You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from:
http://get.adobe.com/reader/
To magnify the text/images in the manual, click the [+] button at the top of the Adobe Reader window as shown in the attached image:
Thanks for using
FixYa.
