20 Most Recent
Casio Twincept Databank ABX238BV Wrist Watch Questions & Answers
Battery Replacement
Do not lay the tweezers across any contacts as you may damage the watch.
First you need to examine your watch movement and find an AC point (contact). Use an eyeglass, as the writings can be very tiny.
When found, touch an AC point with one arm of tweezers and battery+ with another arm simultaneously.
Some watches needs to do that twice, so, to be sure, do that twice.
If
you are not comfortable with tweezers, you can use a thin wire,
connecting one end of the wire to AC point and another to battery+.
Each shortcut should last for 3 seconds.
Do not forget to rate, please.
Hi I need to know:
DXB - DubaiKBL - KabulKHI - KarachiDEL - DelhiDAC - DhakaRGN - Yangoon/RangoonBKK - BangkokHGK - Hong KongTYO - TokyoADL - AdelaideSYD - SydneyNOU - NoumeaWLG - WellingtonHNL - HonoluluANC - AnchorageLAX - Las Angeles (Airport)DEN - DenverCHI - ChicagoNYC - New York CityCCS - CaracasRIO - Rio de JaneiroLON - LondonPAR - ParisCAI - CairoJRS - JerusalemJED - JeddahTHR - Tehranhttp://cyecorp.ro/dailylog/2012/01/07/cities-world-time-on-watches/
ABX-66
On most casio watch you can see AC (all clear) point , youy need to resset clock connecting this point with + on battery about 5 sec.
I have same problem but on my watch I do not see AC point. :)
regards
ststefan
Re Casio Waveceptor watch
limited info generic answer if its the lower $ end units-- pop off the back --and remove internals careful of springs for buttons --check for debris -failed spring-button bi-metal fail /damaged
