20 Most Recent JVC LT-32X575 32 in. HD-Ready LCD Television Questions & Answers
I have a JVC LT 26X575 that will not accept remote
sounds like the remote batteries could be bad or the buttons on the remote need to be cleaned. some JVC TV remotes, I'm not familiar with this particular one though, can be cleaned using a clean pencil eraser. Be careful opening the remote because some parts can fall out or you can damage the connections to the LED emitter that sends the signal to the TV. Also the solder connections on that LED could be bad.
1/4/2018 12:11:28 PM • JVC LT-32X575 32... • Answered on Jan 04, 2018
0answers
JVC 32 inch LT-32DY8ZJ T turns on...shows green light....then turns to standby then back on then off again. Can this be repaired?
Good day..That problem is usually cause of bad capacitors on the power supply section..As you stated your TV works fine and after a minute the red light comes on...That symptoms is cause of bad capacitors..Normally bad capacitors can check visually if the capacitors look like leak/bulged on the top that is the indication of bad one but not all bad capacitors are bulged some are not so in that case you have to used a special meter called capacitance meter..This is the sample picture of bulged capacitors:12_6_2011_5_59_01_am.jpg
9/29/2013 3:53:19 PM • JVC LT-32X575 32... • Answered on Sep 29, 2013
Sharp 32inch lc-32A33M turns on screen blink lamp off and again picture appear and picture blink and lamp also off two times then green light turn off and red led illuminate means set goes in to the
add 47k to back light high voltage referance to ground.dont allow those voltage upto 3.1v.it will work. (asifrazi @hotmail.com)
5/9/2013 2:02:45 AM • JVC LT-32X575 32... • Answered on May 09, 2013
HOW DO WE TUNE THE TV FOR DIGITAL CHANNELS
If your using basic cable then just use auto program and the set does the rest. You will only get the hd stations your cable provider provides using basic. If you use their hd cable box and pay for more hd stations then you will have more.
12/3/2010 8:39:09 PM • JVC LT-32X575 32... • Answered on Dec 03, 2010
tip
JVC LT-32X575 LCD TV Manual Download
Download JVC LT-32X575 LCD TV Manual
Would you like to review the features of the JVC LT-32X575 LCD TV ?
Have you lost your JVC LT-32X575 LCD TV Owners Manual?
Would you like a digital, searchable, pdf version of the JVC LT-32X575 LCD TV Users Guide?
Follow this link (& click FREE) to download a pdf version of the JVC LT-32X575 LCD TV documentation.
I hope that helps.
___________________________________________
2answers
JVC LT-32DS75SJ issue with HDMI
Try this
1. Turn ON TV
2. Connect PS3 to TV HDMI input
3. select TV HDMI input for PS3
4. turn OFF PS3 if it is ON
5. Press and hold the [I/O]Power button until the PS3 until you get the "HDMI Detected" message.
Also, this TV has a circuit that deactivates the HDMI if the rear cover is removed. It is possible the HDMI may have been turned OFF. This is reset in the service menu of the TV.
3/16/2010 1:45:13 PM • JVC LT-32X575 32... • Answered on Mar 16, 2010
Our tv has a split screen - it is a lt 32jm30. we
Try looking for 'PIP' button on the remote.
12/23/2009 3:50:44 AM • JVC LT-32X575 32... • Answered on Dec 23, 2009
Jvc lcd cracked screen
LCD is one of the expensive part of a Monitor. maybe you can buy a new one because if you choose to repair it, it cost the same when you buy a new one.
2/27/2008 11:15:43 AM • JVC LT-32X575 32... • Answered on Feb 27, 2008
My JVC 58in. Flat screen blinks?
The cable connections for your TV are not connected properly or are loose or the cables might have damage or the connection ports are broken.
12/6/2022 5:26:37 PM • JVC LT Televison... • Answered on Dec 06, 2022
2answers
The USB will not work for pausing live TV how can I fix this?
no info generic answer read owners manual or search online for one
5/14/2022 12:50:19 PM • JVC LT Televison... • Answered on May 14, 2022
JVC TV model,s avk14t3-1 has sound and no picture in audio-video mode
it needs service, that means using tools and meters and spare parts to find cause. dead screen black screened at all times.? even in HD TV antenna mode for HD TV? or just the remote CLICKER batteries dead. tell things that work and no not work , even LED actions. the maker has no books on this old TV https://jvcproducts.com/us/contact/support.html here they are ask them>? what rare TV. good luck fixing any RARE TV. moved you to TELEVISION.
3/24/2022 11:25:05 AM • JVC LT Televison... • Answered on Mar 24, 2022
TV is just over one month old - screen started getting darker and darker in pathes, now more than 60%, tried resetting all settings to default, tried all inputs (Video, HDMI, RF) all the same result -
Return it to your place of purchase and get something else anything else you wouldn't believe how many people are having Issues with the LT series get rid of it.
1/4/2018 12:22:16 PM • JVC LT Televison... • Answered on Jan 04, 2018
NO POWER LIGHT OR STANDBY LIGHT COMING ON
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electro-medical.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge)
3/10/2016 7:13:11 PM • JVC LT Televison... • Answered on Mar 10, 2016
HOW DO I GET 4 DIGIT ACTIVATION CODE FOR IRISH TUNNING
Look for the manual of your Universal Remote and find the code assigned to your TV.. If no code, follor proper procedure for "no code available!"
8/25/2015 8:15:27 PM • JVC LT Televison... • Answered on Aug 25, 2015
A JVC LT42XM48 LCD Television set. Takes power has no picture or sound.
As a first step , if it is controlled via the remote, check that the remote batteries are good and that it is functioning ok. Does the tv show anything att all? If it does come on but shows nothing then it might be that the source selection is on the wrong kind of source, you can find on the remote whether this is so by going to the source menu which should probably be on digital. (I am assuming that you only have digital broadcasts where you are. If there is no picture whatsoever ubplug the set and check whether the internal fuse(s) are ok.)
6/8/2015 7:33:54 PM • JVC LT Televison... • Answered on Jun 08, 2015
JVC LT-32X575 32 in. HD-Ready LCD Television Logo
Popular Tags
21 questions posted
Top JVC Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
 Grubhead
Grubhead
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
LT JVC
  • LT JVC
Most Popular Question
sharp 32inch lc 32a33m turns screen
  • Televison & Video
