20 Most Recent
JVC XV-S300 DVD Player Questions & Answers
How do I scroll down the menu with no remote
Often the keys on the unit, like the FWD REV etc will allow the cursor to be moved? But if not, then indeed you are stuck, and would have to get another remote. Also get a manual, it may show you how in there too?
We have sound on our jvc dvd but no picture weve
Hello
plug in and tighten the connections on the back of the DVD player, the television and any amplifier, if there's no picture or sound. Plug the DVD player's outputs into the amplifier's inputs. Then plug the amplifier's outputs into the television's inputs. Sometimes the amplifier is called a receiver.
How do I make
hi,
Try the following to make your dvd player region free
1. Make sure there is no Disc in the tray.
2. Shut off the unit and unplug it from the AC outlet.
3. Press and Hold the "Play" and "Open/Close" keys, simultaneously on the player and not the remote control.
4. While holding these keys, plug the AC cord back into the outlet. (TEST and CPU ver# will appear on the display)
5. Release the "Play" and "Open/Close" keys.
6. Press DVD Menu twice on the remote.
7. When the display reads s000 5858 use the up and down buttons to change the 000 to 02E.
8.
Using the Left and Right arrow buttons, change the last four digits
until they read 0000 for Region Free, 0101 for Region 1, 0202 for Region
2 or 0404 for Region 4.
9. Press Enter on the player.
10. Press Standby and wait 5 seconds.
11.
Press Standby again. Your player is now set to the region you
requested. If you find some titles do not play on the region 0 setting,
you may have to hard select the appropriate region.
ok
The power button is on
If Your players power is on and refuses to open, it is either the disc tray is jammed or the mechanism is not functioning properly, what You have to do is to service the mechanism, To service the disc tray please follow the steps below:
- The instrument You will be needing is a screwdriver and gloves,
- Power off the player,
- Unplug it from the power outlet,
- Then You allow it to rest for about 6 hours, Then You put on Your gloves, and unscrew the screws around the player,
- Take off the players cover and check the mechanism on the left side of the player,
- Plug in the player then You power in on, press the open button and see if it will attempt to open, once it attempts to open,
- Then You apply a little force in pushing the disc tray in the direction it is supposed to open,
- Pull it out and in several times till it seems free and opens on its own when You press the open button,
- If it still does not open on its own, then it means the mechanism is bad and need to be replaced.
- To replace the mechanism, just carefully disconnect it and get a replacement,
- Reassemble the replacement into the player,
- Then You try to open the player, it will work this time,
- Reverse the process to reassemble the player back together.
Hope this helped. Thank You for using FixYa!!!
WILL NOT POWER ON
The power panel is bad and needs replacement.
Replace the power panel and it will be in good conditions once again.
Take care
DVD is hook up and no picture on the TV.
You have to make sure that the RCA cables are properly connected to the TV. Check the TV/Mode if it's set to AV1 (Audio/Video1) or AV2. You may check the TV remote to set it to AV1 or AV2.
From the DVD, the cable should be connected to OUT. And on the TV...video and audio should be connected to IN.
Error message when reading DVD
Try changing the region setting to region free.
8.
Region 2 or 0404 for Region 4.
11.
Good Luck. Let me know if it works
Region 1 only DVD player
Most company and people who have the codes sell them, so i suggest u google for DVD REGIONAL CODES, some will give u a thirty day trial version, but in most cases u have to buy the software
JVC 43" (109cm) HD Ready Plasma TV PD43N30A. Chunghop universal remote codes for JVC pd43n30a
Question edited for a lot more clarity, plus
Chunghop not chungCHOP :>D
JVC: 089, 161, 909
CHUNGHOP Universal Remote Control Codes
codesforuniversalremotes.com
https://codesforuniversalremotes.com > chunghop-univer...
Jul 25, 2019 -
CHUNGHOP Universal Remote Control Codes ; Aiwa: 009, 057, 058 ; Samsung: 618, 619, 620, 621 ; Philips: 013, 023, 024 ; Hisense: 676, 677, 707, 898
My JVC TV has an onscreen remote that doesn't let us use the actual remote what do I do to gat it out?
Hello! If your JVC TV is displaying an onscreen remote and you're unable to use the actual remote, you can try the following steps to resolve the issue:
- Power cycle the TV: Turn off the TV and unplug it from the power source. Wait for a few minutes, then plug it back in and turn it on. This can often reset any temporary issues and restore the functionality of the actual remote.
- Replace the remote batteries: Check the batteries in your remote control and make sure they have enough power. If the batteries are low, replace them with fresh ones and try using the remote again.
- Check the remote control sensor: Ensure that there are no obstructions between the remote control and the TV's remote control sensor. Clean the remote control sensor on the TV with a soft, lint-free cloth to remove any dust or debris that may be interfering with the signal reception.
- Reset the TV to factory settings: If the issue persists, you can try resetting the TV to its factory settings. Keep in mind that this will erase any personalized settings and restore the TV to its original configuration. Refer to the user manual or the manufacturer's website for instructions on how to perform a factory reset on your specific JVC TV model.
- Contact JVC customer support: If none of the above steps resolve the issue, it's recommended to reach out to JVC customer support for further assistance. They will have access to more specific troubleshooting steps and can guide you through the process of resolving the issue with the onscreen remote.
Keep in mind that the exact steps and options may vary depending on your specific JVC TV model. Refer to the user manual or contact JVC customer support for model-specific guidance.
JVC SR-DVM700U the front display is dimming quit low to where i cant read it
If the front display of your JVC SR-DVM700U is dimming to the point where it is difficult to read, there are a few potential causes and troubleshooting steps you can try:
1. Adjust the display brightness: Check if your device has a dedicated display brightness control. It could be a physical knob or a setting in the menu system. Increase the brightness setting to make the display more visible. Refer to the user manual for specific instructions on how to adjust the display brightness.
2. Check the power source: Ensure that the device is connected to a stable power source. If the power supply is fluctuating or inadequate, it can cause the display to dim. Try plugging the device into a different power outlet or using a different power cable to rule out any power-related issues.
3. Clean the display: Dust, dirt, or fingerprints on the display surface can also affect visibility. Gently clean the front display using a soft, lint-free cloth. Avoid using harsh chemicals or abrasive materials that could damage the display.
4. Check for backlight issues: The display might have a backlight that illuminates it. If the backlight is malfunctioning or failing, it can result in dimness. Unfortunately, in most cases, repairing or replacing the backlight requires professional assistance. Consider contacting a qualified technician or JVC customer support for further guidance and potential repairs.
5. Reset the device: Perform a factory reset on your JVC SR-DVM700U. This can help resolve any software-related issues that may be affecting the display. Consult the user manual or contact JVC customer support for instructions on how to perform a factory reset on your specific model.
If the above steps don't resolve the issue, it is recommended to reach out to JVC customer support or consult a professional technician who specializes in JVC audio/video equipment. They can provide further troubleshooting guidance or recommend appropriate repairs if necessary.
