20 Most Recent
JVC HR-XVC33U DVD Player/VCR Questions & Answers
EP to LP problem on VHS tape playback
The problem is dirt, dust or even mould on the VHS tape. You should look on youtube for video's about cleaning a VHS tape. However if it's really bad there is nothing you can do about it. Commercial VHS were only recorded on SP so the quality of the tape means more signal, so less of a problem keeping the video tracked, even if the tape has patches of mould, likely if kept in a basement!
Does my JVC HR-XVC33U have
Greetings Lightfingers - Your unit is only capable of viewing DVDs and has no capability for burning DVD's
If you would like to burn DVDs you can buy a burner for a PC for about $20-25 USD at a place like newegg.com.
Regards and thanks for using Fix Ya.
Mikeywaf
I am missing the remote
Partstore has them for $29.95
http://www.partstore.com/Part/Matsushita/JVC/HRXVC33U/Matsushita/JVC/LP21036033B/New.aspx
Unable to change for taping.
Hi
Thanks
for using FixYa. On the unit Press
VCR/DVD repeatedly so that the DVD
indicator lights up. On the Remote press
DVD so that the DVD indicator lights
up. Please check whether the
“F-1” or “L-1”
has been selected as the input mode. Set the desired channel. Press PAUSE to pause the recording, change
channels, then press PLAY to resume
recording.
Please do
accept the solution if the issue is resolved or else revert for further
assistance.
Thanks
Rylee
VCR Part not working
To fix the problem the unit must be takena apart to check connection to VR unit.
This is a job for a technician.
DVD won't read discs
try cleaning thelens inside the unit.use a clean cotton ball to wipe the surface of the lens.DONOT USE ANY LIQUID!! extra care..
Split Screen Output
check on the remote if got some function of format ntsc or pal or check on the menu of the dvd
Dvd region unlock
Here you go, Go to this website all the info you need is here,
http://www.fixya.com/support/p186635-jvc_hr_xvc33u_dvd_player_vcr_combo/manual-17143/page-6
If that don't work let me know I'll find out exactly what to do, Thanks hope it helps you out.. Happy Holidays
Vcr
try this it has a lot of info.
JVC HR-XV33U DVD/VCR
Press and hold the Progressive Scan button for more than 3 seconds. It should clear right up.
