20 Most Recent Nextbook 8" LCD 1GHz Processor Wi-Fi Tablet w/ Android 4.0 NEXT8P12 Questions & Answers
Unable to download anything keep being told insufficient memory.
Start by checking storage space available. some older versions of android have a nag of accumulating useless data in some corners of the system. You may not be able to see what uses the space, but at least it will tell you if there is space or not. To help you, i need to know if there is actually any storage left or not. This can be found in "settings -> storage" Note: Internal storage = the onboard storage from the factory. memory is the RAM, nothing can be saved here. So if you have an EXTERNAL micro sd put in, please provide this information.
4/12/2016 10:43:21 AM • Nextbook 8" LCD... • Answered on Apr 12, 2016
Can I use the battery charger for the Nextbook 10 on the Nextbook 8?
You Could use it but later as years go by the Nextbook 8 battery weakens. There i suggest not use it!!!
11/18/2015 8:15:01 AM • Nextbook 8" LCD... • Answered on Nov 18, 2015
Is there a recall on nextbook 8
no there is not
3/15/2015 2:49:43 AM • Nextbook 8" LCD... • Answered on Mar 15, 2015
Why does my nextbook 8 when fully charged show an exclamation point in the battery? and when I unplug it it totally drains the battery?
Can mean the battery isn't communicating its status to the tablet--failing battery, bad connection, etc. Talk to tech support for a replacement if it's still under warranty. If it's not and you can still charge it to 100%, hang on and hope for the best.
8/12/2014 3:45:47 AM • Nextbook 8" LCD... • Answered on Aug 12, 2014
Why does my Nextbook tablet say server error or not connected when I try downloading apps because I am connected to my cell hotspot?
Question edited for clarity. 'Cause' and 'because' are two different words with different meanings and are not interchangeable. Because you are connecting via a relay and not direct is the most likely answer. Access to apps and the credit cards that are linked to them can't go via a third party device.
3/5/2023 6:45:46 AM • Nextbook Tablets... • Answered on Mar 05, 2023
Nextbook 8P won't reset. I have tried troubleshooting instructions with no result
you are having trouble resetting your Nextbook 8P. Here are a few steps you can try to reset your device:
  1. Soft Reset: Hold down the Power button until the device turns off, then turn it back on.
  2. Factory Reset using the Settings: Go to "Settings," then "Backup & reset," and finally "Factory data reset." Confirm the action and wait for the reset to complete.
  3. Factory Reset using Hardware Buttons: If you are unable to access the settings menu, you can try resetting the device using hardware buttons. To do this, you will need to follow these steps:
  • Power off the device
  • Press and hold the Volume Up button and the Power button
  • Release the buttons when the Nextbook logo appears
  • Press the Volume Down button to navigate to "wipe data/factory reset" and press the Power button to select it
  • Confirm the action by pressing the Volume Down button to select "Yes" and the Power button to confirm.
If none of these steps work, the device may have a hardware issue and it may be necessary to contact the manufacturer or a professional repair service for further assistance.
2/13/2023 2:24:35 PM • Nextbook Tablets... • Answered on Feb 13, 2023
How do I get my nextbook ares 8A up and running
1/20/2023 3:00:05 AM • Nextbook Tablets... • Answered on Jan 20, 2023
Nextbook NX16A10132S Brightness Setting Won't Work Correctly.
Try to do it opposite way round or go to setting a display
7/29/2022 11:20:08 PM • Nextbook Tablets... • Answered on Jul 29, 2022
I can't make a email on my nextbook premium 8se
Try using email app on play store
7/29/2022 11:15:22 PM • Nextbook Tablets... • Answered on Jul 29, 2022
How do I fix my Nextbook 10.1 if I accidentally plug in a 12 volt charger instead of its 5 volt charger?
You just buy a new one, or everything inside it, power supply, and motherboard. Take it to a computer repair shop. Make sure you tell them what happened.
5/1/2022 5:09:07 PM • Nextbook Tablets... • Answered on May 01, 2022
2answers
Forgot pattern to login to my Nextbook tablet, how can I get into it.
No there isn't. the only thing you can do is a hard reset and scrub it clean!
12/17/2021 11:45:31 PM • Nextbook Tablets... • Answered on Dec 17, 2021
What does the exclamation mark next to the wifi icon on my nextbook tablet mean?
Wi Fi is not configured properly.
9/3/2021 12:00:11 PM • Nextbook Tablets... • Answered on Sep 03, 2021
Nextbook tablet not recognizing bluetooth tablet that's been paired
Set the country code to your country.
6/18/2021 6:04:53 AM • Nextbook Tablets... • Answered on Jun 18, 2021
I can't get nextbook to go into safe mode. How do I fix this problem
Hello Dear, this might help you go into safe mode To get into "Safe Mode" please do the following. 1. First turn off the tablet. 2. Next press and hold "Power" until you see the manufacturers logo on the screen, then release the power button. 3. "Quickly" press "Volume Down" and hold it for few seconds until you see the message "Safe mode: ON" or something similar. 4. If you wanted disable it, simply repeat the steps above, and you should see "Safe Mode: OFF" rather than on.
3/12/2021 8:06:05 AM • Nextbook Tablets... • Answered on Mar 12, 2021
Why is it running really slowly?
You will have to uninstall every app that has been downloaded and also one by one and then test the tablet in normal mode after each uninstall apps to see if the performance issue has been fixed . If it has then the last remaining app which is uninstalled is the culprit.
2/11/2021 6:39:30 PM • Nextbook Tablets... • Answered on Feb 11, 2021
Downloaded game apps will not play on nextbook tablet. As soon as they try to load they immediately go off without allowing me to play the games.
im typing on pc but back to me when i just open games like amung us cant spell it rigth it just says dis game wont work and im mad at nextbook right now so next book give us a reason why games dont work on your tablet
12/10/2020 3:07:12 AM • Nextbook Tablets... • Answered on Dec 10, 2020
Nextbook 8" LCD 1GHz Processor Wi-Fi Tablet w/ Android 4.0 NEXT8P12 Logo
8 questions posted
Top Nextbook Tablets & eReaders Experts
NOEL
NOEL
john h
Are you a Nextbook Tablet and eReader Expert? Answer questions, earn points and help others
View Most Popular
  • Nextbook Tablets & eReaders
Most Popular Question
unable download anything keep being told
  • Tablets & eReaders
