20 Most Recent
JVC UX-S57 CD Shelf System Questions & Answers
When I turn on the
Hello
Hello
The microprocessor inside may confused either due to enormous external commands of by any external electrcial field. just unplut the device from AC power plug, and reconnect it again after 5 minutes or so. If this process does not solve the problem, the internal power suppy section of the set have some trouble with it. If there is less or absolutely no voltage to the microprocessor memory section, the processor cannot go forward after switch ON, and will shut down. If so the set need service. Get it serviced by any experienced service technician or by the authorises service center for JVC. OK.
When you press the standby
hi,
ur systems output amplifier have some problem. there may be voltage at its output, that's why its go to standby to protect ur speakers. check the output amplifier stage,
ok
MP3 Connection
Here you go:
http://resources.jvc.com/Resources/00/00/95/GVT0134-001B.pdf
JVS UX S59, every time original disc inserted
the main problem with this is the laser .
the category 1 lasers are very sensitive .
the solution is to make sure your cd's are clean , not scratched and the final thing to do is clean the lenses of your JVC S59 make sure to keep this unit in a dust free enviroment .
CD changer won't open
There may be a jammed disc in the mechanism - if there is no manual release near the door (there isn't usually on these systems), you may have to open the case and look to make sure there's not a disc jammed somewhere in there.
Jvc CA-MX50BK
hi if you know how to open this unit first check fuse,transformer and the main cable ac, thats all you can do take it for qualefied service........saludos
CD deck
That means that there is a mechanical error concerning the tray gears
DVD TRAY WILL NOT EJECT
it is definately jammed and will need to be taken apart and unjammed safely to avoid dammage to the unit
