20 Most Recent
JVC HX-Z10 CD Shelf System Questions & Answers
My JVC CA-HX-Z10 works just fine but the speakers
This is a semiconductor or capacitor thermal problem. You will have to be able to get to the circuit boards. With a can of Electronic Cold Spray (freon), you turn the unit on until it heats up and the sound goes out. Then, try spraying transistors and components once at a time, until the sounds comes back on. This will be the bad part. You will have to unsolder it and take it to Radio Shack or electronic parts store, or possibly order one online (google the part number, or value on the capacitor, etc.). Problems like these are usually transistors, and they usually only cost a few dollars (maybe $25 at the most). Inspect solder joints to see if they're cracked, or discolored (indicating a "cold-solder" joint, which you can resolder with fresh solder applied. The hardest part of fixing this type of problem, is that you have to sometimes take it all apart to get at the back of the circuit board to unsolder the bad part. Take pictures as you take it apart- they will help you putting it back together. Good luck!
System seems to operate fine but no sound
there is something that is called a relay in side of the set when u open it u will see it were u put the speaker wires behind that two black boxes those are the relay look between them n see if any thing had burn if so u need to change that part of reach me at 742-2520 if u want
Cd shelf
The hx-z10 mini stereo system is giving me the same problems again.
Turn on Daily On Alarm Clock
The instruction manuals are on this link;
http://books.jvcservice.com/booklist.asp?Model=HX-Z10
Hope this helps :)
I have a JVC RX-501 reciver and 2 speakers Sony(200W). I start the reciver and After 3-4 seconds it S make a sound like" bun bun " that S all... After 1-2 minute again..
The sound you're hearing could be due to a variety of reasons, such as a loose connection, a malfunctioning component, or a power issue. Here are some steps you can take to troubleshoot the issue:
Check the speaker connections: Ensure that the speaker wires are properly connected to the receiver and the speakers. Make sure that the positive and negative terminals are correctly aligned. You can also try disconnecting and reconnecting the wires to ensure a secure connection.
Check the power source: Ensure that the receiver is plugged into a working power outlet and that the power cord is securely connected to the receiver. You can also try plugging the receiver into a different power outlet to see if that resolves the issue.
Check the volume level: Ensure that the volume level on the receiver is not set too high. High volume levels can cause distortion and other issues.
Reset the receiver: Try resetting the receiver to its default settings. To do this, turn off the receiver and unplug it from the power source. Wait for a few minutes, then plug the receiver back in and turn it on.
If these suggestion don't help, you may have to seek professional repair.
2/2/2024 9:08:57 PM •
JVC Audio...
Answered
on Feb 02, 2024
1997 JVC RC-X270 does not read CDs
A bit of basic knowledge is required first;
Insert CD, the first thing the processor expects is to scheive Focus.
When Focus is acheived, the Spindle Motor will turn.
Either the Laser cannot Focus or there is an issues with the Spindle Motor.
Which is it ... if you know, then you will know which part or board has the issue.
1/29/2024 6:36:28 PM •
JVC Audio...
Answered
on Jan 29, 2024
