20 Most Recent
JVC RX-7010V Receiver Questions & Answers
Display shows an
Hi Mobius,
Two things cause the overload warning.
- High Volume
- A short in one of the speakers.
Click here to view a downloadable copy of the manual. Refer to page 38.
Best regards
Mike
I am using an optical
Where does the digital audio REALLY originate - the TV or something higher up the food chain like a Cable Box?
Try getting it from the source to make sure it works. Then, if you REALLY think the TV needs digital 5.1 and an intervening run of cable before it passes audio to the JVC, connect it as the book says.
The TV can probably survive just fine with a simple RCA stereo audio patch from the cable box just in case you want to watch CNN without the JVC turned on.
When my unit powers on, it clicks in the back and
The most common problem found on FixYa for Audio Video Receiver's is:
My receiver say's "Protect" or turns on then off. What's wrong? Seven times out of ten it is a shorted speaker or speaker wire. To determine your exact problem, the first step is to disconnect all speaker wires "at your receiver" Next: Turn the receiver back on. If your receiver still says "protect" or turns off, it needs to be serviced. If your receiver stays on; reconnect your speakers one at a time and power back up after each speaker. You may find that after reconnecting all speaker wires it works! Most commonly the small braids of wire from the + to the - have touched and have caused the problem. In some instances, you noticed the problem only when turning the volume up. either way, make sure the exposed wires to your receiver are no longer than 1/2" long and are completely under the screw down terminal or slide in. When you've found the wire or speaker with the problem, your receiver will go back into "protect" At this point, disconnect the wire from the speaker at the speaker that may be causing the problem then test again.* Note* Make sure speaker wires do Not touch each other as this Will cause a short! If you turn the receiver back on and it stays on, you now know the problem is in your speaker itself. To test your speaker, you will need a multimeter. Set it to ohms resistance and touch the speaker terminals, if there is a short internally the meter will read "1......" If it's an analog meter, it will peg to the right. There's your problem. Now, within any speaker there are quite a few possibilities as to what could be causing the problem. Most common is a blown coil and the speaker needs to be replaced. Some speakers have internal crossovers (usually floor standing speakers) and may have a shorted or burnt board (usually very visible brown burn marks on the board) and can possibly be repaired if your handy with a soldering iron. Now, if you disconnect the speaker wire at the speaker and it still says "protect" Check your wire for the obvious cut or nail thru the wire if possible. If your system has wiring that runs behind walls, you may need to use your meter again. Disconnect the wire at both ends, keep the ends separated, put your meter on ohms resistance and touch probes to the + and - wires at one side. If the meter pegs to the right or reads "1...." the wire is shorted and needs to be replaced or repaired at the short. Hope this helps.
I have a JVC RX-501 reciver and 2 speakers Sony(200W). I start the reciver and After 3-4 seconds it S make a sound like" bun bun " that S all... After 1-2 minute again..
The sound you're hearing could be due to a variety of reasons, such as a loose connection, a malfunctioning component, or a power issue. Here are some steps you can take to troubleshoot the issue:
Check the speaker connections: Ensure that the speaker wires are properly connected to the receiver and the speakers. Make sure that the positive and negative terminals are correctly aligned. You can also try disconnecting and reconnecting the wires to ensure a secure connection.
Check the power source: Ensure that the receiver is plugged into a working power outlet and that the power cord is securely connected to the receiver. You can also try plugging the receiver into a different power outlet to see if that resolves the issue.
Check the volume level: Ensure that the volume level on the receiver is not set too high. High volume levels can cause distortion and other issues.
Reset the receiver: Try resetting the receiver to its default settings. To do this, turn off the receiver and unplug it from the power source. Wait for a few minutes, then plug the receiver back in and turn it on.
If these suggestion don't help, you may have to seek professional repair.
2/2/2024 9:08:57 PM •
JVC Audio...
Answered
on Feb 02, 2024
1997 JVC RC-X270 does not read CDs
A bit of basic knowledge is required first;
Insert CD, the first thing the processor expects is to scheive Focus.
When Focus is acheived, the Spindle Motor will turn.
Either the Laser cannot Focus or there is an issues with the Spindle Motor.
Which is it ... if you know, then you will know which part or board has the issue.
1/29/2024 6:36:28 PM •
JVC Audio...
Answered
on Jan 29, 2024
