20 Most Recent Acer Aspire V5-122P-0864 11.6" Touch Laptop Questions & Answers
HOW TO DOWNLOAD CLNPWD.EXE PROGRAM
8/16/2019 2:32:47 PM • Acer Aspire... • Answered on Aug 16, 2019
Acer aspire v5-122p black screen
try connecting a monitor to determine if the issue is with LCD or power issue with the laptop
4/24/2019 4:16:47 AM • Acer Aspire... • Answered on Apr 24, 2019
3answers
How to recover my windows password
2/7/2018 8:08:52 AM • Acer Aspire... • Answered on Feb 07, 2018
How do i get rid of a horizontal line
It is a bad LCD. It may just be bad timing. Buy a new display on eBay for $50 and look up a video on how to replace the LCD on your particular laptop model. When ordereing, make certain to order the correct display! Matt finish versus glossy and screen size.
11/17/2015 2:44:46 PM • Acer Aspire... • Answered on Nov 17, 2015
Touchpad buttons stopped working. movement of mouse works fine
Are the drivers installed for the touch pad? Try reinstalling the drivers or go into the setting for your touch pad and see if the buttons are disabled. Try the link.Possibly it can help you. What to do when your laptop touchpad stops working
11/13/2015 3:40:21 AM • Acer Aspire... • Answered on Nov 13, 2015
How do I add Boot devices to Boot Menu on Acer V5-122P
This model is intregated with windows 8 you may boot other devices by enabling legacy mode but during this your original boot manager may removed after that you not be able to boot previous windows
2/24/2015 4:52:11 PM • Acer Aspire... • Answered on Feb 24, 2015
How do I add Boot devices to Boot Menu on Acer V5-122P which only shows the internal HDD
Because this is one of the thin client laptops all you have in the laptop is a Hard drive. and other boot device is a USB device that you plug in. As such the bios will not show it until it is plugged in and then you can select it to boot from.
2/18/2015 8:43:03 PM • Acer Aspire... • Answered on Feb 18, 2015
How do i reconnect with an existing wireless network when it cannot be found
Check the router's settings - it may not be broadcasting SSID any more, or it may have stopped working altogether; it may need to be rebooted. The problem may not have anything to do with your laptop.
8/8/2014 3:55:03 PM • Acer Aspire... • Answered on Aug 08, 2014
My new-bought Acer Aspire 3 has yellow acer logo when starting up, is it normal? Because in some yt videos, the acer logo is green
Perfectly normal. It depends on the internal timing of the GPU and the OS version.
4/17/2024 3:01:26 AM • Acer Computers &... • Answered on Apr 17, 2024
tip
Mpowering technology pop up
Couldn't get rid of mpowereing technology pop up. Tried every solution offered by the internet. Finally I noticed when I powered up my computer the pop up showed up even before the computer loaded anything. I turned off the power to the monitor and powered it back up an viola, pop up gone. The Acer monitor had generated the pop up.
2answers
My Acer X1110 switches off as soon as blue light comes on?
it needs service, and service manuals are hard to find on anything by the likes of ACER. this projector worked for 12 long years, did you own it 12 or bought a bad projector, no history told as I can buy dead projectors all day long. and hard nut problems even hacking done. Acer X1110 data projector Standard throw projector.. did you know most projectors have serious grade protective devices inside??? (tamper and overheating are 2) did you read owners manual page 32 yet, errors. LED codes.? there are 4 LED, and all 4 matter, projector turned (ON) (not one =1) also in pairs glowing and also if blinking or not, so read page 32 it tells all that. my guess is overheat failures, even cold, due fan slow or packed in lint after 12 years of use and no service done,. color-undefined-undefined-0.jpg https://manualzz.com/doc/49497108/acer-x1110-user-manual some have dust filtler a shop first cleans is out first, and check fan RPM with and LED tachometer. this is all SOP.
4/2/2024 4:37:58 PM • Acer Computers &... • Answered on Apr 02, 2024
''e'' button :acer empowering technology
That button can be set using the utility on your programs list
It maybe that you accidentally turned it off or set it to do some other task.
Start there first before re-installing the program that sets it.
That is on one of the cds that should have come with it and can be installed by itself.
1/25/2024 8:38:32 AM • Acer Computers &... • Answered on Jan 25, 2024
Gud day my motherboard model is acer b25h4-am pc i forgot the password in bios so i decided to clr_cmos jumper and take out the cmos battery to clear the password of my bios,
I would try starting up and go straight into the BIOS. Set up your system and reboot.
1/23/2024 7:25:53 AM • Acer Computers &... • Answered on Jan 23, 2024
2answers
I can't use bluetooth on my Acer Aspire 7520
This computer does not have Bluetooth capabilities and you can't make it, by adding a Bluetooth Driver. It would need a Bluetooth transmitter and receiver HARDWARE built into the computer at the time of manufacture.. https://icecat.biz/en/p/acer/lx.akg0x.146/aspire-notebooks-aspire+7520-6a2g16mi-1376542.html and this site actually says it. https://www.bhphotovideo.com/c/product/538918-REG/Acer_LX_AN20X_017_Aspire_7520_5757_Notebook_Computer.html/specs Wireless Wi-Fi: 802.11b/g Bluetooth: None ..
11/27/2023 12:05:13 PM • Acer Computers &... • Answered on Nov 27, 2023
Acer 7240 turns off when unplugged
bad battery
10/21/2023 9:29:10 PM • Acer Computers &... • Answered on Oct 21, 2023
CCFL Laptop Screen Inverter
If Laptop is ok and screen is ok then I suggest check the ribbon cable connectors. Are all wires ok ? For information, CCFL Service manual is here https://clubelectronicos.com/wp-content/uploads/2020/11/lg_inverter_t-con_board_repair.pdf and Acer Aspire 8930G Service manual is here Acer Aspire 8930G Service Manual (Page 107 of 119) ' ManualsLib
10/18/2023 1:07:27 PM • Acer Computers &... • Answered on Oct 18, 2023
2answers
Hi could you please tell me if there is caps lock illumination , on ACER ASPIRE 3 LAPTOP. Thank you.
Most laptops have a tiny lamp that illuminated the Caps Lock and Num buttons. These are used to remind the typist they are locked and for error messages when the motherboard won't start properly.
7/28/2023 6:35:14 PM • Acer Computers &... • Answered on Jul 28, 2023
Acer Aspire V5-122P-0864 11.6" Touch Laptop Logo
11 questions posted
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
View Most Popular
  • Acer Computers & Internet
Most Popular Question
download clnpwd exe program
  • Computers & Internet
