20 Most Recent
LG RZ-17LZ40 17 in. LCD Television Questions & Answers
Power Failure
you can solve the problem by opening the back cover of the television to check for blown fuses at the power stage of the printed circuit board, if found , replaced with the same current rating but if otherwise Ur power supply board is dead ,tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hope this will help....
I have a Sharp Aquos lcd37 that appears to have
From your description, it sould like your back light might be starting to fail. Is it VERY darker or just a little? You might look for signs of it being not bright uniformly or giving a slight flicker interittently. If so, the backlight is the issue. This light is a flourescent light that sits right behind the LCD array shining through it to you to see. Some of hte Aquos models are replaceable by the end user, where others are a unit which includes the balast (high voltage circuit). Because it is a 37 inch unit, I expect it comes as a module set. The price on these can be a little high, but not to the point of buying a new TV. You might be looking around 200.00 roughly plus labor to put the thing inside... that will depend on the skill of the installer :-) I am not sure if hte parts are available to the public for this from Sharp, but I would definitely let a pro install it for you since it requires taking off the LCD array, and you do NOT want to mess with that fragile item yourself. Hope that gives you an idea what you are against. Thanks!
mrstan
How to replace lcd tv bulb
Most of those models you replaced them through the front. The lower front panel pulls off. Some models have a knob that must be loosen on the back of the set at each end. Once the front panel is taken off the Lamp door is easily accessed. The new Lamp from Sony will come with the proper Wrench to remove and reinstall lamp.
Hope this helps,
Skyassoc
PSU?
Look for any capacitors that my be puffed up or leaking. most of the time just replacing them fixes the problem.
Lcd tv backlight prob
You need to replace the inverter board if you can find the spare part. Otherwise you need to replace the whole lcd panel.
