20 Most Recent LG DVD 6053 DVD Player Questions & Answers
3answers
Not able to play mkv
LGDV6H wont play mp4. IT plays well mkv, avi and other formats.You will have to convert files to mkv to play and its very easy. Download mkvtoolnix from http://www.bunkus.org/blog/ and use the program mkvmerge. add your files and mux it. BEWARE after adding and before muxing please select each track and go to 'extra option' and select in compression 'none'. Then mux it and play the mkv file. Trust me it works. It has worked for me.Even mkv files that wont play can be muxed again with the previous settigns and then it plays. Its taht simple.
3/15/2022 3:40:46 AM • LG DVD 6053 DVD... • Answered on Mar 15, 2022
2answers
I have a LG DV6H
Yes you need to convert it. LGDV6H wont play mp4. IT plays well mkv, avi and other formats.You will have to convert files to mkv to play and its very easy. Download mkvtoolnix from http://www.bunkus.org/blog/ and use the program mkvmerge. add your files and mux it. BEWARE after adding and before muxing please select each track and go to 'extra option' and select in compression 'none'. Then mux it and play the mkv file. Trust me it works. It has worked for me.Even mkv files that wont play can be muxed again with the previous settigns and then it plays. Its taht simple.
12/11/2019 9:11:19 AM • LG DVD 6053 DVD... • Answered on Dec 11, 2019
manual
Hi, i have LG DVD
Hi Coelhosc For LG HD DV6H Media Player1. Start DVD with no disk, wait for no disk in display.2. Press "0" zero for 5 to 10 sec till screen appear3. Press pause4. Press "0" for 5 sec (both setting must be "0" for region free)5. Press pause again.All ready to go.
11/29/2011 1:36:07 PM • LG DVD 6053 DVD... • Answered on Nov 29, 2011
Wont play mp4 of flash
This model does not support both those format of video and there is nothing you can do about it except buy a new model.
9/13/2011 6:20:45 AM • LG DVD 6053 DVD... • Answered on Sep 13, 2011
0answers
My LG dv490h DVD player has its DVD drawer jammed
The DVD tray has come off the alignment or settings which make it come OFF the mechanism. So you will need to push back the drawer back to the set position and this might be possible only after the loading mechanism is pulled out. The loading gear would have meshed with the loading drawer at mid way -due to the pull--and so it connecting only half way.
If mechanically minded you can remove the tray mechanism and reset the tray to the gear position in the DVD play/stop position.
2/8/2011 10:01:27 PM • LG DVD 6053 DVD... • Answered on Feb 08, 2011
4answers
LG DVD 6053 Disc tray does not open
This happens to my dvd player all the time. I know this sounds bad but I give it a few quick taps on the top of the player just after I press the open button and it opens for me. I have the same player as you also.
See how you go with it!!
9/8/2009 3:04:58 PM • LG DVD 6053 DVD... • Answered on Sep 08, 2009
Unlock the coding for dvd player lg dvd 6053
HI, paste link below into your browser and follow the instructions. The unlock code for the 6053 is the same as for the 5931. Simply burn the disc and put it in your player. I used this site to unlock mine, very worthwhile.
http://www.multi-region.net/lg_5931
4/3/2009 7:15:45 PM • LG DVD 6053 DVD... • Answered on Apr 03, 2009
I have a LG dvd player 5083 inserted the disc the correct way into the draw but the machine does not play the disc a very slight humming noise is heard then it spits the drawer back out
Clean the Lens: Use a DVD cleaning disc to clean the lens. If the problem persists, consider professional cleaning. Test Other Discs: Try playing different DVDs to see if the issue occurs consistently. If it's specific to one disc, that disc might be the problem. Check for Updates: Make sure your DVD player's firmware is updated. Refer to the manufacturer's instructions for firmware updates. Try a Different TV: Connect your DVD player to a different TV to see if the noise disappears. If it does, the issue might be with your TV. The hum is simply the player trying to read the disc. It can't so, it spits it out. Remember that prolonged use of a malfunctioning DVD player could potentially cause damage. If the problem persists, consider seeking professional repair or replacement
4/19/2024 8:46:44 PM • LG Televison &... • Answered on Apr 19, 2024
3answers
Fuse diagram for a LG plasma model pdp42v80201
The screen blank out
4/7/2024 11:03:07 PM • LG Televison &... • Answered on Apr 07, 2024
LG Plasma TV is not displaying picture when it is turned on
This is the Power Board for it. check those 6 electrolytic Capacitors on the right for bulging or splitting. Don't buy it blindly, it's a guess. The output voltages with a digital multimeter. https://applianceparts.com/item/10217204/LG/EAY62812602/ Many parts are obsolete. eBay has used boards, but they are risky because they are out of scrapped sets. https://www.google.com/search?q=50PN5300-UF+power+board We have a television expert named Larry, but I haven't seen him for a while. This used to be my advice https://www.fixya.com/support/r29790007-repairing_own_television ..
3/30/2024 8:59:29 PM • LG Televison &... • Answered on Mar 30, 2024
3answers
DVD reading problem on a LG DVD5083 DVD player.
Maybe the disk is not compatible with the DVD player version
3/24/2024 9:16:41 AM • LG Televison &... • Answered on Mar 24, 2024
How do I program my DVD video remote control to my LG Blu Ray surround sound player please?
It can't be done. The DVD remote will be single frequency for that device only and the LG remote for that LG Blu Ray (or series) only. Companies don't make cross-control between makers easy. The only exception is cable and satellite boxes to allow their remote to also control the television. If you have lost a remote or it doesn't work, this is the answer https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote ..
3/19/2024 4:25:52 PM • LG Televison &... • Answered on Mar 19, 2024
LG DVD 6053 DVD Player Logo
Popular Tags
17 questions posted
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
View Most Popular
  • LG Televison & Video
Most Popular Question
wont play mp4 flash
  • Televison & Video
