20 Most Recent Marantz CC-4300 5-Disc CD Changer Questions & Answers
Hi - the CD tray cannot open. It is empty - no
The loading tray belt has more than likely stretched or snapped.The buzzing you hear will be the motor spinning freely. The 'ERROR' message will show up because the tray isn't openingand activating the 'tray open' switch, therefore the 'tray closed' switchis permanently activated after the 'open/close button is pressed.
7/16/2012 9:49:50 PM • Marantz CC-4300... • Answered on Jul 16, 2012
Error message
I had this happen to me as ell. you've probably got a cd stuck under the revolving tray. I took the top cover off and then opened the drawer and removed the offending disk. If you're not technically minded it's probably better to take it in to a repair shop. Mike
2/27/2008 1:21:28 PM • Marantz CC-4300... • Answered on Feb 27, 2008
Noisy changer mechanism
If the moise sounds like a stretched spring, it is most probably tracking noises you are hearing. Try cleaning the focal lens. It may have have a layer of laser dustus interuptus on it making the servo drives work hard. Do this with a cotton tip moistened with Windex, then a light gentle polish afterward with a dry one to be sure that no residue of smearing is left. If the problem persists, then more involved work will need to be done to the unit. Maybe realignment of tracking and focus servos(they are producing the noise)and or a replacement laser fitted and and then subsequent realignment. Sometimes you can back off the servos to allow for quieter operation. Experience here is the best teacher. Good luck, hope this snippet of info helps you. If it doesn't, happy to talk further on it, but you may need to sharpen you optic alignment skills ;)
regards
Graeme
2/14/2008 11:55:11 AM • Marantz CC-4300... • Answered on Feb 14, 2008
Marantz CD5004 tray keeps opening problem
CD/DVD players use a protocol; Open tray. Insert disk. Tray switch tells mechacon that the tray is shut. Attempt to focus on disk. If focus is acheived, then it will spin up and try to read the disk otherwise it will ask for a readable disk. If the tray keeps opening, I would suspect the tray detect switch is malfunctioning, maybe the drive belt has stretched.
3/1/2024 9:19:51 AM • Marantz Audio... • Answered on Mar 01, 2024
2answers
Marantz TT400 Turntable. Has just stopped revolving altogether. Is it likely to be a belt issue? Connection ok as stylus still makes a noise if touched.
Yes. Most probably belt is broken. Download the service manual from given link and replace the belt as per procedure given in the manual. Marantz TT-4000 Service Manual, Service Manual, Repair Schematics (electronica-pt.com)
2/11/2024 11:19:11 AM • Marantz Audio... • Answered on Feb 11, 2024
Where can I locate a Marantz SR-66 User Manual? I can find the service manuals, but not the user manual.
This is very strange the Service Manual is free and everywhere, but on the Marantz website if you scroll down to the bottom there are dozens of SR- Models in the AV Receivers category but it completely overlooks the SR-66, but there is an SR-6006! https://www.marantz.com/en-us/support/product-archive%C2%A0 It exists though https://www.hifi-review.com/149388-marantz-sr-66.html I would contact Marantz Support. https://www.google.com/search?q=Marantz+SR-66+owner%27s+manual ..
2/7/2024 11:41:26 PM • Marantz Audio... • Answered on Feb 07, 2024
Marantz CC870 100+1 Disc CD Player Changer manual, requesting pdf
Question edited for full 'make model (what it is). Question moved to Marantz. It is very old, but help here https://www.google.com/search?q=Marantz+Cc870+manual ..
1/26/2024 8:08:44 PM • Marantz Audio... • Answered on Jan 26, 2024
3answers
Reset Marantz sr5006 to factory settings
Hold the 'display' and 'zone select' buttons, then press power. Display should blink all segments. Let go of buttons, and your good to go
12/30/2023 7:51:01 PM • Marantz Audio... • Answered on Dec 30, 2023
Marantz SR5005 help with zone 2?
It is a nice gift! Specs state Multi-Room Speaker Out Assignable Surround Back Speakers as for Zone 2 Speaker A/B Yes Looks like Page 47 of the manual onwards
SR5005
Marantz https://www.marantz.com > sr5005_u_en_ug_v00 1. Read these instructions. 2. Keep these instructions. 3. Heed all warnings. 4. Follow all instructions. 91 pages
Marantz SR5005 User Manual - ManualsLib
ManualsLib https://www.manualslib.com > ... > Receiver > SR5005 View and Download Marantz SR5005 user manual online. AV Surround Receiver. SR5005 receiver pdf manual download.
12/6/2023 11:04:59 PM • Marantz Audio... • Answered on Dec 06, 2023
Is the Marantz SR68 an FM tuner please?
No, it is a Surround Sound Receiver for taking television signal, or a signal from another device and amplifying it to multiple speakers.. https://www.google.com/search?q=Marantz+SR+68 ..
2/21/2023 4:20:06 AM • Marantz Audio... • Answered on Feb 21, 2023
HI, would you know what error code CY920 on my Marantz NR1607 means ?
The Marantz NR1607 is an AV Receiver, and the CY920 error code is not a recognized error code for this product. It's possible that this is a custom or specific error code for your device, and I would recommend contacting Marantz support or the manufacturer for more information. They may be able to provide you with a solution or more information on what the error code specifically means and how to resolve it.
2/12/2023 3:15:35 PM • Marantz Audio... • Answered on Feb 12, 2023
The poweramp of my Marantz SR6004 AV Surrount Receiver only turns on after about 3 minutes.
Parece que el problema puede estar relacionado con la fuente de alimentaci?n de su dispositivo. Es posible que desee verificar si la fuente de alimentaci?n proporciona el voltaje y el amperaje correctos. Adem?s, es posible que desee verificar si hay conexiones sueltas que puedan estar causando una interrupci?n en la fuente de alimentaci?n. Tambi?n puede intentar restablecer el dispositivo a su configuraci?n de f?brica para ver si eso resuelve el problema. Si estas sugerencias no funcionan, es posible que deba consultar el manual para obtener pasos de soluci?n de problemas m?s detallados o ponerse en contacto con un t?cnico calificado para obtener ayuda.
1/6/2023 9:04:51 AM • Marantz Audio... • Answered on Jan 06, 2023
Marantz DV 9500 DOES NOT PLAY ANY of normal CDs. Reads ONLY Super Audio CDs. What could be the cause for this fault?
  1. Hardware issue: The CD player may have a hardware issue, such as a damaged laser or faulty electronics, that is preventing it from reading normal CDs.
  2. Firmware issue: The CD player's firmware, which is the software that controls the device, may be outdated or corrupt, causing it to only read Super Audio CDs.
  3. Compatibility issue: The CD player may not be compatible with normal CDs, and is only able to read Super Audio CDs due to their specialized format.
In terms of adjusting the laser pick-up, it is generally not recommended to try to adjust the laser pick-up yourself, as it can be a delicate process that requires specialized equipment and knowledge. If you believe the issue may be related to the laser pick-up or other hardware, it may be necessary to seek the assistance of a qualified technician or the manufacturer. If the CD player is unable to read the content of a normal CD and is returning to 00:00 tracks on the display, it is possible that the issue may be related to the laser pick-up or other hardware. It is also possible that the issue may be related to internal ICs or other electronics, in which case it may be necessary to diagnose the issue further to determine the cause and find a solution.
12/25/2022 6:51:14 PM • Marantz Audio... • Answered on Dec 25, 2022
My Marantz SR6003 doesn't work with optical anymore. How come?
Have you tried a new cable?
12/19/2022 8:10:55 PM • Marantz Audio... • Answered on Dec 19, 2022
Marantz CC-4300 5-Disc CD Changer Logo
11 questions posted
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
xxxxxx xxx
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Marantz Audio Players & Recorders
Most Popular Question
noisy changer mechanism
  • Audio Players & Recorders
