20 Most Recent
Microsoft LifeChat LX-1000 Headset Questions & Answers
Hi this is erum here
Hi Erum,
The hardware specification for this device is supported on Windows 7 also. The below link has the information from Microsoft
http://www.microsoft.com/hardware/en-us/p/lifechat-lx-1000#details
Did you check if the music is audible when it is plugged.
8/13/2011 11:00:04 AM •
Microsoft...
Answered
on Aug 13, 2011
Have Windows XP and Lifechat
Hey! If you try to install this does it work properly?
http://download.microsoft.com/download/F/7/0/F70FBF72-2AAB-4D60-9E49-7B015E8E5851/LifeChat1_4.exe
Otherwise did it come with an installation cd?
2/28/2011 7:40:26 AM •
Microsoft...
Answered
on Feb 28, 2011
I have installed the software and connected the
plug in the headset first then install the software . i had the same thing happen to me . so i just plug in the headset first then installed the software . it works just great now . ok. frank.
How to wire a fridge thermostat
Wiring a fridge thermostat typically involves connecting the thermostat to the power source and the compressor. Here's a general guide for wiring a 3-pin thermostat:
- Identify the Pins: The thermostat will typically have three pins labeled 4, 6, and 3.
- Connect the Power Source: Pin 4 is usually the common (C) terminal, which connects to the power source. This could be the live wire from your electrical supply.
- Connect the Compressor: Pin 6 is often the normally open (NO) terminal, which connects to the compressor. This allows power to flow to the compressor when the temperature rises above the set threshold.
- Ground Connection: Pin 3 is commonly the ground (GND) terminal. This should be connected to the ground wire for safety purposes.
4/19/2024 7:20:26 AM •
Radio...
Answered
20 hours ago
Realistic scanner police codes
I recommend RadioReference.com, they have detailed lists from all over the United States. In addition to frequency lists, they also include live audio, HAM radio lists, licensing information and a lot more.
4/4/2024 5:32:44 AM •
Radio...
Answered
on Apr 04, 2024
Serial Number for KPG-790
All questions need FULL 'make model (what it is) first 3 words please.
Something to do with this? The serial number should on the label on the rear by the mains cable. This is a statutory requirement unless someone removed it to hide its identity.
https://www.google.com/search?q=KPG-790
2/15/2024 3:06:45 AM •
Radio...
Answered
on Feb 15, 2024
