20 Most Recent
Canon PIXMA MX860 All-In-One InkJet Printer Questions & Answers
What is error 6C10?
On which copier? If it's kyocera mita then it's the brakeage of the heater thermo fuse.....or your electricity current.
My Canon MX860 is printing, or attempting too print, everything (including Word) in PDF.
Sounds interesting! Uninstall the printer and all it's utilities from your pc. Sounds as there might be a bit of corruption in the print driver. Try a roll back of your o/s to a time when it was printing correctly. Then do a disk cleanup, a defrag. Have a restart of your system and then reinstall the software the printer
The roll back/recovery might clear any issues that have happened since all was working correctly. The disk cleanup will clear all the junk on the machine that is extraneous. The defrag should put all files into locations where their contiguity ensures you have a smoothly functioning machine. It may also overwrite some of the
faulty software belonging to the old installation of the printer
Sounds like a fine plan, and it should work.
How do I set the date on a canon mx860
Key Menu, then tools or setup [OK],
from maintenance - arrow key left or right to device settings [OK]
arrow down to user settings [OK]
That should put you into the menus for changing date, time etc. You should also check your daylight saving and locationsettings while you're in thereWhen done use the back arrow to step all the way back out.
How to clean absorber on a MX860
Anonymous,...This is a critical warning from the printer since when the printer detects the waste ink absorber is full it will shut the printer down. What Canon wants you to do is to bring the printer into their Service Facility and have it totally cleaned. The labor for this and the new parts required will cost much more than a new printer,..and therefore you will buy a new printer. However if you have the time and skill my Repair Manual will instruct you how to do all of this yourself. You can reach me at bud4golfatattdotnet.
How do I reset or fix an Error B200 Code on a Canon PIXMA MX860 Printer?
Dear
Please try the following to see if we can resolve your issue:
1. Open the cover of the printer.
2. Remove all ink tanks from the printer.
3. Lift up the gray locking lever on the side of the ink tank holder.
4. Gently remove the print head from the carriage unit.
5. Place the print head back in and lock the lever down.
6. Place all of the ink tanks back in the printer.
7. Close the cover and turn the printer off.
8. Unplug the power from the printer. Leave the power unplugged for about 5-10 minutes.
9. Plug the power back in and turn the printer on.
Thanks
Is there a fuse in the pima mx860 that could keep it from powering on ?
No. The fault will be with either the mains cable/plug/socket on wall.
The power supply in the machine (its a sealed unit) or the SCNT Board. Its unlikely to be the operation panels on/off switch.
When you try to turn the machine on, listen to it. Do you hear a buzz or in fact any sound at all? If you do then it will be the board. If you don't then its more than likely the power supply. Also look at the screen, do you have any black squares on it? If so then again its the board.
