20 Most Recent
Vollrath 40734 Questions & Answers
Vollrath granita vcbf168 3 head machine slush machine one of the augers isn't turning but can see inside the cylinder the auger drive is turning
If one of the augers in your Vollrath Granita VCBF168 3-head slush machine is not turning, but you can see that the auger drive is turning, there may be a few possible causes for this issue:
- Auger blade or shaft issue: Check the auger blade and shaft for any damage or obstruction. Make sure the blade is properly attached to the shaft and rotates freely. If there is any damage or blockage, you may need to replace the auger blade or shaft.
- Belt or pulley problem: The auger drive is typically connected to the auger itself via a belt and pulley system. Inspect the belt and pulleys to ensure they are intact and properly aligned. If the belt is worn or the pulleys are misaligned, it may prevent the auger from turning. Adjust or replace the belt or pulleys as needed.
- Motor malfunction: The auger drive motor could be experiencing a malfunction. Check if the motor is running smoothly and listen for any unusual sounds. If the motor is not functioning properly, it may need to be repaired or replaced.
- Electrical issue: Ensure that the electrical connections are secure and there are no loose or damaged wires. Check the motor's power supply and voltage to ensure it is receiving the correct amount of power. If there is an electrical problem, it may require professional repair or assistance.
Maplin N20FR - damp test meter. I have no
N20FR - Used to measure the moisture level in sawn timber (also cardboard, paper) 6 to 44% on the left hand scale and hardened materials (plaster, concrete and mortar) 0.2 to 2.0% on the right hand scale
4/14/2024 9:12:34 PM •
Kitchen...
Answered
on Apr 14, 2024
