20 Most Recent TORK Mechanical Hardwired Timer 1101-O Questions & Answers
check to ensure that the dark lever is set to desired off time silver to desired on time
TORK Mechanical... | Answered on Jul 11, 2018
Try removing the batteries overnight and then start again. Put battery in the main unit first and then the remote.
Home | Answered 21 hours ago
Which flush mode makes it sound like that? Does it ever get stuck filling and you have to make it stop?
Home | Answered Yesterday
MIGHT HELP US IF WE KNEW THE BRAND OR MAKE OF IT . MY SHOWER HEAD HAS NO FILTER THE WHOLE HOUSE HAS ONE THO
Home | Answered 2 days ago
PROBABLY FROM THE MANUFACTURER.YOU PLUG IT IN AND TURN IT ON
Not a common problem - last time I encountered the problem, limescale had jammed the ball valve closed.
Home | Answered 3 days ago
It's probably an override switch for some sort of programmable feature
Home | Answered on Nov 11, 2019
The unit is 8.5KW. Therefore, it has to be a 220/240V circuit and running about 40A. I would not splice the wires at that power level.
If the wire is accessible, you may be able to unattach it and pull out a few more mm, otherwise I would replace the whole line.
Home | Answered on Nov 07, 2019
read the instructions that come with the kit
Home | Answered on Nov 06, 2019
TORK Mechanical Hardwired Timer 1101-O Logo
5 questions posted
Top TORK Home Experts
Donni Steen
john h
Are you a TORK Home Expert? Answer questions, earn points and help others
View Most Popular
TORK Home
  • TORK Home
Most Popular Question
all lights not coming when timer set set
  • Home
