20 Most Recent
Tommy Hilfiger Sport Stainless Steel with Plastic bezel 1780916 Watch for Women Questions & Answers
Watch stopped working 11 months
It is best to go to a watchmaker for this issue. If the battery was improperly installed, it can damage the movement or contacts, which will mean the movement must be replaced. We see this issue often. Another common problem is that the oils from the installer's fingers may be causing a bad connection if the battery and the contacts are not properly cleaned. We would use the Pulse test to see if the watch has current, if so, the movement is bad mechanically, it must be replaced. If it has no current, we would check and clean all connections and replace the battery. If there is still no current (using Pulse diagnostic) then the movement is bad and it must be replaced.
Does anyone know how to adjust dual time. Cant seem to adjust the second time..Tommy Hilfiger 1791709
To adjust the dual time on a Tommy Hilfiger 1791709 watch, you will need to follow these steps:
- Locate the crown (knob) on the side of the watch.
- Pull the crown out to the second position. You should feel a slight resistance as you do this.
- Turn the crown clockwise or counterclockwise to adjust the time on the second time zone. The time on the main display will not change.
- When you have set the correct time, push the crown back in to the original position.
It is important to refer to the user manual for your specific watch model for detailed instructions on how to adjust the dual time feature. If you are unable to adjust the dual time on your watch, it is recommended to have it serviced by a professional watch repair technician.
I was given a tommy
One of the twist setting knobs may also be a digital, try holding for 10 secs, then date will blink, use other kn9b to toggle up and down, then return original , press once to set.
