20 Most Recent
Compaq Operating System Solution Kit For ACS (222322-B21) for PC Questions & Answers
Product key
buy the key online, otherwise you can be put in prison for theft. i will send my old vista basic key to your gmail as i use windows 7 now.
I have windows vista home basic 32 bit operating
if you have disc use it and use the product key that came with it doesn't expire ! unless you have a hacked version of it, or get a key generator from online and run when to find an open key for it that is the only thing to do other wise call the OME and ask for a recovery disc to you PC that's it
the fixist good luck and have a nice day
Produt key
Ultimate: 6F2D7-2PCG6-YQQTB-FWK9V-932CC
Business: 72PFD-BCBK8-R7X4H-6F2XJ-VVMP9
Home Premium: 8XPM9-7F9HD-4JJQP-TP64Y-RPFFV
Home Basic: 762HW-QD98X-TQVXJ-8RKRQ-RJC9V
Hurry up.. Go ahead and activate your Vista online..
if it doesn't work.. use the All in one activator.. that will 100% surely help you
WINDOWS VISTA
_______________________________________________
Ultimate:6f2d7-2pcg6-yqqtb-fwk9v-932cc
Ultimate:2qbp3-289mf-9364x-37xgx-24w6p
Business:368y7-49ymq-vrcty-3v3rh-wrmg7
Business:72pfd-bcbk8-r7x4h-6f2xj-vvmp9
Home premium:bh626-xt3fk-mjkjh-6gqt2-qxqmf
Home premium:8xpm9-7f9hd-4jjqp-tp64y-rpffv
Home premium:2tybw-xkcqm-xy9x3-jdxyp-6cj97
Home premium:2r6wf-kyf88-27hyq-xtkw2-wqd8q
Home premium:gp3fq-jb647-7cw8f-h646b-7pmgf
Home premium:34bkk-qk76y-wwr7c-qf2m7-2tb37
Home premium:4gptt-6ryc4-f4gjk-kg77h-b9hd2
Home basic:2wp98-khth2-kc7kg-4yr37-h8phc
Home basic:762hw-qd98x-tqvxj-8rkrq-rjc9v
My Windows XP system has
You may have a virus infection.
Try running a virus scan on your computer.
Next, press the F8 function key as you boot up and then select "Last known Good Configuration" - if this doesn't work
Next, press F8 again as you boot up and then select "Safe Mode"
If you can get the computer running by either of these two methods, go to Control Panel and then to Administrative Tools - Event Viewer and check for error messages to determine the problem.
If nothing works, then I suggest you formating your computer and re-install Windows.
Out of frequency range set lower resolution
reboot the system by pressing F8 if your using windows OS and select last good configuration.
you can try also selecting Enable VGA mode (press F8 while rebooting and select ENABLE VGA mode).
hope this helps, please rate.
I want to install xp on compaq nx 6310 give the procedure with pendrive
2006 PC (HP.coM) 16 years old.. ouch.
XP (microsoft) is now a horrible virus magnet, and there is ZERO support now, are you using the last XP earth 2020???
gee google that. 2001 to 2007 was XP rein , vista 2007
I bet there are 1millons of web site still with XP usage .(old topics)
google them. but Microsoft purged theirs.
it is not sold at all, so how in the world can you get the installer on any pen drive, and XP installed from CD not pen..
worst of all XP installer, can not us 99% of all USB ports and then only half after the install (unless you force them via F6 and floppy drive with xp drivers on the floppy for THIS PC)
to use any relic PCs run LINUX> not XP
