20 Most Recent
MyMusix MX-F01 MP3 Player Questions & Answers
MyMusix mp3 player with a MS-DOS (FAT16) format
Mac should able to detect the MP3 format. unless you chage it by mistake.
Mac has its own format issue. this I think you should ask Apple, since both these are Apple porduct. they should have better answer than I can provide.
good luck
FORMAT ERROR
The format of the music file is not supported by your player. Please convert the file format to .mp3
Formatiar
Preformat : By Fix-shad0w
#1
Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
#2
Open up 'My Computer'. You should see it under the list of available drives.
#3
Check its contents first to make sure that you have the right drive.
#4
In 'My Computer', right-click on the drive and choose 'Format'.
#5
Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
#6
Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
With A USB , CELLPHONE , Camera The SameThing
It won't turn on???
I realize that this question was asked quite a few months ago but my just did the same thing and tonight and what needed to be done is the contacts cleaned where the battery is. Did this and it turned right on.
HOW DO I DELETE THE SONGS ON MY MP3 PLAYER
You can generally connect the device to the computer and see the information under My Computer>Device Name.
Then you can manually add or delete music from the device.
Best of Luck.
Just out of box Craig CMP616F blinks on and off or
i had the same problem with mine searched online and found that someone said to let the battery run completely dead, that resets it, and then you charge it for 4 (i think) hours. Worked for mine and I hope it works for you too
Reformat internal media as FAT16
Go to the Mymusix website and download the player update utility
(located here:
http://mymusix.mmvoice.com/products/audio/PD-6070/software.html )
install it, then use these instructions
http://mymusix.mmvoice.com/products/audio/PD-6070/PD6070Vistaonlyfaq.html
Starting at step 9.
I never got it to actually complete the update process, but it did format it, which solved the problem.
MyMusix PD 6030 persistently displays
I would recommend you do back up your files to the computer and then format the player.
Q: How do I format my
PD-6030?
A: There are various
way to format the PD-6030.
With Windows XP, go
to Start, All Programs and select 'My Computer'. Then see if
there is a device called an 'Audio Player' listed there. If so ,
open the Audio Player and right click the item named 'Internal
Storage' and select 'Format'. Once the format is complete,
unplug the player and turn it on. Once it turns on and says 'No
Files' plug it back in to your PC and add the music back to the
player.
With older version of
Windows, the player will show up under 'My Computer' as a
'Removable Disk'. Right click that and select "format'.
How do i put music on my mp3,4 free
depending onm its name brand or your computer you might be able to use a media service like windows media player to sync the songs on to the device. If you want to download songs for free i would say limewire or frostwire. although most people wont use it because of th risk of viruses i have used it for years with almost no problems at all. the problems i did have with limewire was it takes up alot of space on my computer. frostwire isnt as bad for taking up space but it doesnt have as many songs as limewire.
How do I change to degree mode on my porpo YH-2000
- Power Off: Turn off the device.
- Jumper Configuration: Locate the jumper labeled "S16" on the device. Initially, it should be connected to pins 2 and 3.
- Power On (Alarm+All LEDs Flashing): Turn the device back on. You'll see the alarm LED and all other LEDs flashing.
- Power Off Again: Turn off the device once more.
- Jumper Adjustment: Change the jumper configuration from pins 2 and 3 to pins 1 and 2.
- Finished: Your Porpo YH-2000 is now set to the desired angular unit mode.
If you encounter any issues, you can press the reset switch on the back of the device to reinitialize it.
Openfit Shokz battery replacement?
Question edited for clarity, typo and CAPS.
Question moved from Cars and Trucks category.
Claim on the warranty irrespective of how long you have had them. They charge $180 but they cost them $20 to buy from China. Package them up and send them tracked and ask them to replace the batteries.
How long is the warranty on AfterShokz?
While we hope you never need it, all new Shokz purchased from authorized retailers come with a two-year warranty that begins on your date of purchase.
Jan 11, 2019
https://www.google.com/search?q=Openfit+Shokz+battery+replacement
My roadking rk4000 wont charge. I turn it off to charge it but there is no indicator light at all, any suggestions?
Are you using the charging cables that came with it? That is a type C. Are you securely attaching the charging cable? A loose connection would keep the battery from charging. If you had a low battery, you would see a red light. That you have no light at all suggests there is no charge left in the battery. I'm not sure the reset will work with no charge which is why you ought to check the cables first.
But turn it off and then hold down the Multifunction button for 10 seconds to reset it. Then turn it back on and see what happens. If you can, test the charging cable on aother device. If you have another type C charging cable, try it, just to eliminate a bad cable. If these suggestions don't work, you may try the manufacturer's customer support.
Can f2100 remote work on my dishtv box?
The F2100 remote is not explicitly listed as compatible with the AerialBox T2100, I recommend using the remote that came with your AerialBox T2100 for optimal functionality. If you have any specific compatibility concerns, I suggest reaching out to Dish TV customer support for further assistance.
