20 Most Recent
Nakamichi SoundSpace 12 System Questions & Answers
DVD player is locked
Press and hold the Track
Down button on the player
Press the Power On button
to turn on your player
Wait until the machine
shows "----" on the display
Release the Track Down
Using the main remote
keypad, enter the digits 1, 0, 1 and 1, then press Enter
The machine should now
display "D-00" and be region free
Enjoy ;)
11/6/2013 5:28:13 AM •
Nakamichi...
Answered
on Nov 06, 2013
My Sound Space12 powers on
If the system is connected properly and the main tuner power is on you will see the orange standby light on in the front of the main diamond shaped control unit. If that light is not on, you have not connected the system and power cables properly. If the standby light is not lit, press the power on/off button in the middle of the rectangular processor/tuner to turn it off and unplug the main power cord from the main tuner/processor from the wall. Next, ensure that all of the power, video and audio cables from the diamond shaped control unit are properly connected to the large tuner/processor. Since you are there, check any other av in/out connections. Now that you have checked and adjusted the cables between the controller and the tuner, plug the tuner back into the wall and push the power on button. Now check the standby light again on the diamond shaped controller unit.Once that light is lit, press the silver, horizontal on button in the middle of the diamond shaped display unit, or the Power Standby/On button on your main remote control and you are operational.
5/19/2012 2:45:57 AM •
Nakamichi...
Answered
on May 19, 2012
Remote control touch screen is not working
Flip ipen the front face of the remote control so that you have access to the buttons underneath. Press and hold the "light" button on the outside right of the remote while pressing the "enter" button to the right of the number "1" button. THIS WON'T WORK IF YOU HIT THE "enter" BUTTON BETWEEN THE ARROW KEYS.The screen should now flash PRESS and VCR 2 - press the onscreen key marked VCR 3. The screen should now flash PRESS aqnd OSD - press the onscreen key marked OSD.Test all of the onscreen keys. If you find them still unaligned, repeat the process.
5/19/2012 2:34:31 AM •
Nakamichi...
Answered
on May 19, 2012
I own a SoundSpace 12.
All
If the lights on the speakers come on normally then they are properly connected. But to ensure this do check them again. Usually surround sound is designed in a way that depending on what you are doing with the unit specific speakers only will be functional.
To check this try changing the sound settings for your device. Toggle between the theatre, hall, rock etc modes. If the speakers are not bad they should function in one of the modes.
Hope this solution has been helpful?
7/26/2010 6:08:17 AM •
Nakamichi...
Answered
on Jul 26, 2010
How to switch off alarm clock on Nakamichi NM-CR-C90
To switch off the alarm on the Nakamichi NM-CR-C90, you can follow these steps:
Locate the "Alarm" button on the top panel of the device.
Press and hold the "Alarm" button for a few seconds until the alarm time display begins to flash.
While the display is flashing, press the "Alarm" button again to turn off the alarm.
The alarm time display should stop flashing and return to the current time.
If the above steps do not work, consult the user manual for further instructions or contact the manufacturer's customer support for assistance.
