20 Most Recent Dell 3200MP Multimedia Projector Questions & Answers
Where to get a cooling fan?
In the US: Parts Express In the UK: CPC or RS Components
9/14/2014 8:12:21 PM • Dell 3200MP... • Answered on Sep 14, 2014
Does hdmi to m1 include audio?
Audio is carried over HDMI, make sure the sound control panel specifies the HDMI port as the sound output.
3/15/2014 8:48:09 PM • Dell 3200MP... • Answered on Mar 15, 2014
Projection horizontal lines and flickering
This is the problem I had with a couple of my projectors, one of them I just replaced the bulb and the other needed whole new brains (controller board)
3/4/2014 10:46:27 AM • Dell 3200MP... • Answered on Mar 04, 2014
0answers
Temp blinking
Be the first to answer 2/25/2014 4:41:36 AM • Dell 3200MP... • Posted on Feb 25, 2014Be the first to answer
2answers
Dell 3200mp
Im not sure sounds like its something internal thats not related to the lamp reset (board or component failure). I have a totally different problem. I have a bad dlp chip and need a donor unit to replace if you dont get this fixed and want to sell it email me @[email protected] and let me know. Good luck thx sean
6/22/2012 5:50:58 PM • Dell 3200MP... • Answered on Jun 22, 2012
0answers
Dell 3200MP DLP Projector: displays OK, but with
You need a replacement color wheel (that is the name of the broken plastic disc, likely glass). I have been unable to source one. Recommend you buy a used projector with a bad lamp, usually less than $100 on eBay and just put your good lamp into it. Keep your old one for parts.
1/15/2012 6:29:54 AM • Dell 3200MP... • Answered on Jan 15, 2012
3answers
Pictue shakes
Sounds like the lamp needs to be replaced. Does the "lamp" light on the top turn solid orange when it turns itself off? That's an indication that the unit has sensed that the lamp is no longer "good".
1/15/2012 6:25:20 AM • Dell 3200MP... • Answered on Jan 15, 2012
2answers
Dell 3200mp lamp not working
Dude! You just saved me 250.00..It worked...I could kiss you!! ...HA! HA!...:)
1/15/2012 6:16:27 AM • Dell 3200MP... • Answered on Jan 15, 2012
I cant unmute the speakers
Hi rheath75,
Kindly refer below on how you will mute or unmute the projector using the menu:
Audio Menu
audio.gif Audio Volume
  • Press bt-decrease.gif to decrease the volume.
  • Press bt-increase.gif to increase the volume.
Treble
Control the higher frequencies of your audio source.
  • Press bt-decrease.gif to decrease the treble.
  • Press bt-increase.gif to increase the treble.
Bass
Control the lower frequencies of your audio source.
  • Press bt-decrease.gif to decrease the bass.
  • Press bt-increase.gif to increase the bass.
Mute
  • Select the left icon to mute the volume.
  • Select the right icon to unmute the volume. .
Hope this helps.
Thank you for using FixYa.
9/25/2011 4:24:34 AM • Dell 3200MP... • Answered on Sep 25, 2011
My dell 3200 mp projector
HI Wolfman,
You need to make sure that the input is correct because there are probabilities that you have it on component.
Thus you need to change it to computer which is RGB (red,green,blue) and then
it should work fine.
Let me know if the problem persists.
Hope that helps...:)
9/12/2011 3:09:22 PM • Dell 3200MP... • Answered on Sep 12, 2011
The image is kind of..green..basicly
If your graphic card output signal is "sync on Green", you should have no problem syncing.
apart from that i need more info
3/19/2011 2:15:06 PM • Dell 3200MP... • Answered on Mar 19, 2011
Suddenly there is no power
1) Replace the power cable or verify that it is working.
2) Verify that the mains supply you are using is working.
3) Check the fuse, if there is one on the body of the projector in a user-servicable location. This would either be a barrel type holder which needs to be unscrewed or a pop-out cartridge type. It will be in the vicinity of the mains inlet. Ensure that the projector is disconnected from the mains before looking for the fuse.
4) If these steps fail to help your projector requires professional repair.
2/14/2011 10:45:44 PM • Dell 3200MP... • Answered on Feb 14, 2011
Dell 3200MP Multimedia Projector Logo
Popular Tags
73 questions posted
Top Dell Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Ngoro
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Dell Office Equipment & Supplies
Most Popular Question
get cooling fan
  • Office Equipment & Supplies
