click start control panel administration tools computer management device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red xright click to reinstall drivers or
if you can see your usb but its not workingports(com&lpt)right click update driver
even if you dont have any red or yellow marks you might have to
Click Start, then type device manager in the Search box then click Device Manager
Expand Universal Serial Bus controllers. Right click a device and click Uninstall. Repeat for each device.
Once complete restart your computer. Your USB controllers will automatically install
This method prevents your USB external drive from powering down
Disable USB selective suspend setting.
This method prevents your USB external drive from powering down.
Click the Start button type power plan in the Search box then click Choose a power plan.
Next to your currently selected plan click Change Plan Settings.
Click Change advanced power settings.
Click the box to expand USB Settings then expand USB selective suspend settings.
Click Plugged in then click the drop down menu and select disabled.
If youre using a laptop click Battery then click the drop down menu and select disabled.
Click Apply then click OK.
if this fails to fix the problem
check usb leads for secure dust free seating
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems hope this helps
if this fails to fix the problem type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter. Then restart computer then check. Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4
if still no luckyou might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap hope this helps
15 questions posted
42 Questions
