20 Most Recent Nakamichi AV-7 Receiver Questions & Answers
try online free user manuals techlog on.....or sfemanuals...makeuseof
Nakamichi AV-7... | Answered on Apr 25, 2013
It definitely has to go through a preamp (a PHONO preamp that is...) something like this: http://www.phonopreamps.com/tc400pp.html
Nakamichi AV-7... | Answered on Dec 18, 2012
If the receiver doesn't have a function specifically named PHONO, yes. Very few AVR's have phono preamps. They're not expensive. I'd check eBay.
Nakamichi AV-7... | Answered on Mar 11, 2012
This could be a number of things and withouit taking measurements internally, there is no way to be sure. Some possibilities include:
1) defective capacitors in the power supply.
2) shorted outputs
3) Open power transformer (either the standby transformer or main one)
To attempt to narrow down the possibilities, listen carefully when yyou attempt to power it on. Do you hear a click? Are there any lights on the unit at all? If the standby circuit is OK, you should see the standby light on.
Please update this with any additional details you can and we'll continue from there.
Thanks,
Dan
Nakamichi AV-7... | Answered on Feb 03, 2010
I need to know bit details on cd eject problem,
1- Do you see Eject / Open in front display of unit when you press Play button?
If yes then it seems malfunction of Key Buttons on player. Use remote of unit to playback cd and check.
2- Does cd player ejects cd after few seconds try to read it and display shows No Disc / Can not read disc error message? If thats the case, it looks cd optical lens is either dirty (requires cleaning) or worn out and requires replacement.
Above info are for Nakamichi cd player and if model and brand is different, let me know.
Thanks.
Nakamichi AV-7... | Answered on Jun 10, 2009
If you're certain there is no sound going out of the TT...
Setting the Pre-amp Switch
For increased flexibility of use, this turntable has an internal
stereo phono pre-amplifier. The Pre-amp Selector Switch
is located under the turntable platter, in the rear-center
(Fig. 1). If the system amplifier you are using has a PHONO
input, set the Pre-amp Selector Switch to the “OFF”
position. If your amplifier does not have a PHONO input,
set the Pre-amp Selector Switch to the “ON” position and
connect the turntable’s output cables to the AUX or other
high-level input on the amplifier (described later).
Turntable operates, but no sound at all
1. The stylus guard is still in place.
2. The tone arm Lift button is pressed in.
3. Amplifier controls set incorrectly: wrong input selected,
tape monitor on, speakers switched off, etc.
4. Check the stylus on phono cartridge for correct placement.
Refer to the instructions for replacing the stylus
on page 5.
Turntable operates, but no sound, or sound not loud
enough
1. If the turntable is connected to an AUX (high-level)
input: The Pre-amp Selector Switch may be set to the
“OFF” position (phono-input level).
2. The input gain of the amplified speaker or similar
device may be too low.
3. The stylus assembly may not be fully seated in the
cartridge body.
You could also isolate the problem to either the TT or the PC by trying the TT on some other sound device like a receiver. Make sure the PreAmp Selector switch is ON and plug the TT into any AUX, CD or TAPE input.
Nakamichi AV-7... | Answered on Apr 24, 2009
its not the fuse problem its the definate problem of ic on the circuit board that has blown out which controls tjhe power on the board to the unit.the number of IC IS -- IC379JC that has to be replaced.also check out the resistor that supplys the power between the capacitor C31011 and IC 379JC.that is resistor number R93 and R94.the cost of the replacing part is not more then $10.but get it replaced and checked fromn a professional repair person in a repair center.it will work after that.
thanks.
Nakamichi AV-7... | Answered on Mar 22, 2009
You are charging me to tell me how to fix it right?
And you want me to tell you how did I fix it for free? I Don't think so.
Bye...........
Nakamichi AV-7... | Answered on Feb 26, 2009
Based on your post, the pre-amp is doing its job. What might be the mismatch would be the powered speaker system plugged into the output of the Rotel. Depending on what the "powered speaker system" is, it might be that it is a low impedance such as those used in computers whereas the Rotel requires high impedance to be connected to its output. What could be tried is to connect a regular amp or receiver to the Rotel.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nakamichi AV-7... | Answered on Nov 05, 2008
in this case the centre speakers are the main route to the sound. 5.1 is for movies, where the centre speaer takes predcedence.
Nakamichi AV-7... | Answered on Sep 28, 2008
This may sound silly, but make sure that the tape monitor switch is not turned on. If it is not, let me know and we'll look elsewhere.
Dan
Nakamichi AV-7... | Answered on Sep 12, 2008
HI
>check the settings on the stereo and see if you have the correct setup: AV 1 ( DTS, Auto, Analog)
If you are using the standard RCA cable (red/White) = Analog
or try the Auto if you are not sure.
I hope this can help
Thanks
Nakamichi AV-7... | Answered on Aug 28, 2008
Nice Receiver!
>In your surround sound settings make sure the levels are set correctly and the distance from your listing point to the furtherest
speakers are set to accommodate the levels etc.
>How many speakers 5.1, 6.1, or 7.1 (1meaning subwoofer)
>Pro-Logic supports 5.1 but not sure about 6 or 7
>Pro-Logic II does support all
>Make sure you are hear the sound from all sometimes the sound is really faint if you are in surround mode
Thank You and good luck
Hello Bangkok, if the plastic doors of the Nakamichi RX505 and Nakamichi RX303, are the same
I send you the links to download the service manuals, where you will find the list of parts and the coincidence of the numbers in both models
Greetings Franco Dosil
Hola Bangkok, si las puertas de plastico de las Nakamichi RX505 y Nakamichi RX303, son iguales
Te envio los link para que descargues los manuales de servicio, donde encontraras el listado de partes y la coincidencia de los numeros en ambos modelos
Saludos Franco Dosil
https://elektrotanya.com/nakamichi_rx-505_e_sm.pdf/download.html
https://elektrotanya.com/nakamichi_rx-303_rx-303e_sm.pdf/download.html
Nakamichi Audio... | Answered on Oct 13, 2019
Nakamichi AV-7 Receiver Logo
Popular Tags
21 questions posted
Top Nakamichi Audio Players & Recorders Experts
Jerry Greenberg
Jerry Greenberg
da surgen
Are you a Nakamichi Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Nakamichi Audio Players & Recorders
Most Popular Question
av 2 surround receiver no sound
  • Audio Players & Recorders
