20 Most Recent Lexicon U22 Ionix U-22 Questions & Answers
My laptop does not recognize
Do you have the correct power supply? MANY try to use a replacement power adapter that puts out DC rather than AC and that will not work.
2/6/2011 6:54:34 AM • Lexicon U22... • Answered on Feb 06, 2011
Whats the polarity of lexicon
Easy answer: You DON'T set the polarity because this particular device takes a 9 VAC at 2.1 amp adapter. (Not a DC one like so called universal ones)
It sounds like you have one of those universal adapters which probably would not deliver the 2.1 amps required even if the lexicon took DC. Note that stuff might light up, but the unit will not work using a DC adapter..
You had better get an official power supply for this unit as what you have will NOT work, period!
I did a quick search to try and find a link to a supplier, but they are RARE !!! Every one I found would require you changing the plug to match the Lexicon.
You should just order the correct one from Lexicon.
2/5/2011 6:55:28 AM • Lexicon U22... • Answered on Feb 05, 2011
0answers
First time.
Be the first to answer 5/17/2017 2:43:43 PM • Lexicon Music • Posted on May 17, 2017Be the first to answer
Can i use my alpha lexicon with audacity instead of cubase?
you SHOULD be able to. Just use Direct Sound in the host tab.
3/19/2017 12:31:23 PM • Lexicon Music • Answered on Mar 19, 2017
0answers
0answers
0answers
0answers
Peavey cs1000 x
The most likely case is that one of the main output transistors (if which there are many) is shorted. When the protect circuit senses DC on the final output, it will not allow the output relay to come on to protect the speakers from raw DC. With the power removed, you can check between each outputs Emitter and Collector and you will probably find close to zero ohms. From that point you need to unsolder each of the pins of the bad channel until you find the shorted device(s) and replace them.
2/7/2024 9:32:20 AM • Music • Answered on Feb 07, 2024
2answers
FRONTIOPAE what is this instrument unscrambled
'pianoforte'
1/17/2024 4:22:56 PM • Music • Answered on Jan 17, 2024
Looking for specific screw for a Crate and Barrel table
BREV. N. 838420
1/9/2024 8:32:24 PM • Music • Answered on Jan 09, 2024
I want to manually wire my z-560
1/4/2024 1:18:20 PM • Music • Answered on Jan 04, 2024
Electronic drum
See page 22 troubleshooting of this manual. It may help you. dd501 (yamaha.com)
1/3/2024 2:26:52 PM • Music • Answered on Jan 03, 2024
No or very little sound from Fender passport
Depending on the model, there are four around that date, it could be the insert jacks are tarnished reducing the signal flow between the pre amp stage and digital power amplifier. It could be the power amplifier has failed. It could even be customer error in wiring. This assumes there is the correct level of signal entering the input sockets of course.
12/31/2023 8:25:12 AM • Music • Answered on Dec 31, 2023
What song did these lyrics come from. (You can set by the water but you just can't drink )
Are you sure you are quoting accurately? Could it be one of these instead? http://www.lyrics.cat/lyrics+lead+a+horse+to+water
12/27/2023 3:43:51 PM • Music • Answered on Dec 27, 2023
Line 6 spider ii head sounds like crap on insane red setting
It's a Line 6 and probably requires a software update from Line 6.
12/24/2023 7:57:43 AM • Music • Answered on Dec 24, 2023
Pricesof yMh PSR 9000 KEYBOARDS
  • Price:$1,099.99 on amazon
11/14/2023 7:53:13 AM • Music • Answered on Nov 14, 2023
Lexicon U22 Ionix U-22 Logo
Popular Tags
3 questions posted
Top Lexicon Music Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Lexicon Music Expert? Answer questions, earn points and help others
View Most Popular
Lexicon Music
  • Lexicon Music
Most Popular Question
laptop not recognize
  • Music
