20 Most Recent
Yamaha YPG-625 (YPG625) Digital Piano Questions & Answers
Why is there no sound
main board problem.. faulty ic.if all oher functions are working..on the main board change ic number ak4385 DAC
Rattling keyboard
Call Yamaha at 714-522-9000 to find local dristubators/ liscend yamaha dealers. You may also visit the yamaha website.
No sound on one key
That's very annoying! The keys press on to a contact strip running the length of the keyboard. Over time this wears out and notes can either stop being dynamic or stop playing altogether. You can buy the strip off ebay and have a go replacing it yourself - not too expensive. I paid someone 50pounds to supply and fit one to a 61-note keyboard.
No power
Inspect if the power input socket of The keyboard it may have a loose soldering or a cold one in one of the tips and may need to be resoldered
Rhythm accompaniment does not play. Start button
Do an initialization (factory reset) by holding the HIGHEST WHITE key down and turning on the power. Hold the key for an extended time until display confirms initialization complete. This will restore unit to factory defaults.
No rhythm accompaniment plays.
The accompaniment parts will begin playing when a chord isplayed in the accompaniment range of the keyboard. Make sure External Clock is set to OFF.
If the problemstill exists, then press the "Portable Grand Button" once. This will reset thekeyboard, and then try again.
Hope this will help you. Good Luck.
YPG625 Humity problem
The overal sound of yamaha YPG 625 and keys operation are exellent by the price. The only problem I eperienced is the instrument operation under high humidity environment. Under this condition many keys sound loud over others, furter more with no expectation from mucisian. This problems is normal for that model because the music store change my previously YPG625 for the same problem<br />
<br />
Sometime I solve the problem to located the instrument under sun exposure and cover the keys and display to avoid direc sun exposure.<br />
<br />
Another is apply with a hair dryers over the keys. But is very disconform situation, and I dont know if the Yamaha exposed this isntrument under high humidity environment durig the product test. I has a Ymaha very low budged digital piano and Roland controller A33 in the same condition and never eperience problems, only with this model.
Will a midi interface allow me to play downloaded music on a yamaha clainova 305
Yes, with some preparation. The music will have to be in a standard MIDI file format or a format that results in standard MIDI over USB output when "played" by computer software or an external sequencer. Within the software you will probably need to create a new "instrument" if there is not already a template for the CVP 305, otherwise the tracks and sub channels in the MIDI file will be patched to GM, probably not what you want to hear.
2/17/2024 11:28:18 AM •
Yamaha Music
Answered
on Feb 17, 2024
What is the best way to reprogram a Yamaha WX5 Ewi
Reprogramming a Yamaha WX5 Electronic Wind Instrument (EWI) typically involves adjusting settings, assigning functions to different keys, or customizing parameters to suit your preferences. Here's a general guide on how you might reprogram a Yamaha WX5:
- Access the Menu:
- Turn on your Yamaha WX5.
- Navigate through the menu options using the buttons or controls on the instrument. Refer to your WX5's user manual for specific instructions on accessing the menu.
- Select Parameter to Edit:
- Once in the menu, find the parameter you want to edit. This could include things like breath sensitivity, pitch bend range, or assigned MIDI channels.
- Adjust Parameters:
- Use the controls provided on the WX5 to adjust the parameters. This might involve turning knobs, pressing buttons, or using a combination of controls.
- Save Changes:
- After making your adjustments, make sure to save your changes. The WX5 typically has a save or store function within the menu. Confirm the changes and save them to the instrument's memory.
- Refer to the Manual:
- Consult the user manual for your specific Yamaha WX5 model. The manual will provide detailed information on navigating menus, adjusting parameters, and saving changes.
- Connect to a Computer:
- Some advanced customization may require connecting your WX5 to a computer using MIDI. You can use Yamaha's dedicated software, if available, to reprogram certain parameters.
- Use External Sound Modules:
- If you're using external sound modules or synthesizers, some customization may need to be done on those devices as well. Refer to the manuals for your MIDI equipment to ensure compatibility and proper configuration.
- Explore Advanced Settings:
- Depending on your proficiency and the complexity of your WX5 model, you might explore more advanced settings like custom MIDI mapping or adjusting sensitivity curves.
Remember to approach reprogramming with caution, especially if you are not familiar with all the settings. Make note of the default settings before making changes, so you can revert to them if needed.
Always refer to the user manual specific to your Yamaha WX5 model for accurate and detailed instructions on reprogramming and customization. If you're unsure or uncomfortable with the process, consider seeking assistance from Yamaha support or experienced professionals in electronic wind instruments.
1/22/2024 6:24:18 AM •
Yamaha Music
Answered
on Jan 22, 2024
