20 Most Recent
Tripp Lite Lite SmartOnLine SU2200RTXL2U UPS System Questions & Answers
I need the default password
User Name: apc
Passwork apc
You must have a network card installed to log into the UPS. Also You must use a 940-1524 APC cable. There is no other way then this. Use putting to log in.
Tripp Lite SU2200 UPS has faults
For Tripplite UPS basically if the fault indicator is on you already have to check the power mosfets/IGBT on the circuit board. if you know the basic of UPS you dont need all those schematic diagram to check the thing. by the way, try to check your battery first if its still working. and if the battery is ok, go and check your inverter
Fault
Battery might be on edge of failing, try to unplug for 1 minute then replug with nothing plugged into the sockets. If OK and it beeps when you plug eqpt into socket the battery needs to be replaced.
