20 Most Recent
Olympus m:robe MR-100 Digital Media Player Questions & Answers
HELP
Did you go to Olympus's m:robe site and download the firmware and install it again?
How can i restart my
on the bottom of your device their is a small hole you will need to find a paperclip or something small and push into that and hold it down to make it reset.
M:robe error invalid/missing file
hello, i had the same problem. recently, i had deleted all the files off of my mr-100. i downloaded this file.
http://www.esnips.com/doc/b15238f2-5133-43e4-b8c4-353375b77088/System_Index
Once you unzip it, drag the System Folder and the Index.mum file directly onto your m:robe. then pull it off the dock. you might have to push reset.
i couldnt get the "invalid/missing file" screen to go away for a while. if you slide the hold button into the hold position and then push the little reset button on the bottom, it will remain off and you can put it on the dock, then it will connect to the PC.
Olympus mrobe
http://www.esnips.com/doc/b15238f2-5133-43e4-b8c4-353375b77088/System_Index unzip
it, drag the System Folder and the Index.mum filedirectly onto your
m:robe. then pull it off the dock. you might have topush reset.
and then freshly install the m:trip software from
http://downloads.olympus-europa.com/consumer/mrobe/m-trip/ENG/
mtrip_english.zip
aftertht
install the
firmwarehttp://www.olympusamerica.com/files/oima_cckb/MR100_FirmSysUp_213.exe..beforeinstalling
the firmware make sure tht u reset the player ..afterfollowing all the
instructions of the firmware try to synch the playerto check whether it
detects music and finally restart your m:robe totake effect..!!
Hi. My name is Natalie. I got an m:robe for my
okey..try this..i got the same problem and i managed to rectify tht
using this method..check it out anyway...first of all try to format
your player in ntfs filesystem and
extract the files to your player and then
mtrip_english.zip
after
tht install the firmware
installing the firmware make sure tht u reset the player ..after
following all the instructions of the firmware try to synch the player
to check whether it detects music and finally restart your m:robe to
take effect..!!
Olympus mrobe 100
i think the problem is with the harddrive and better try to change the wire which has got a link to the board..!!
How do you put music on a mrobe
there is a software named m:trip and i guess ull be having an installation cd of tht when u purchase the music player.else download it from
http://downloads.olympus-europa.com/consumer/mrobe/m-trip/ENG/mtrip_english.zip
and after installing the software ,open the wizard(m:trip) in a small window and drag music to it .After dragging all the music,at the bottom right u may notice something called"synch"press that.. ..after synching u will be able to listen music from yo m:robe player..!!
Invaild/missing file is on the
Remove all the files. Then download all the files from :-
Once you unzip it, drag the System Folder and the Index.mum filedirectly onto your m:robe. then pull it off the dock. you might have topush reset. I couldn't get the "invalid/missing file" screen to go away for a while.if you slide the hold button into the hold position and then push thelittle reset button on the bottom, it will remain off and you can putit on the dock, then it will connect to the PC.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
