20 Most Recent
Sony PlayStation PS Vita PSVita - Black Handheld System Wi-Fi - PCH-1001 Questions & Answers
Sony Playstation 1 replacing the power unit
Before you start make sure that the console is turned off and unplugged before you begin the process. This is for the 1001 model types. With the 5501 and the 7001 and for the 9001 the process might be slightly different.
Step one: Open up the PS 1 console with a Phillips head screw driver and turn the console upside down and remove the 5 15.8 mm-long Phillips #1 screws.
Step two: While holding the top and bottom halves of the console together turn the PS 1 console back over. Lift the top cover straight up to remove it.
Step three: Unplug the power supply and then gently pull out the power supply cable straight up and out of its socket on the power supply to disconnect it.
Step four: Now remove the power supply and then remove the 2 14 mm-long Phillips #1 screws securing the power supply to the bottom of the case.
Step five: Lift out the outer edge of the power supply slightly, and then rotate the whole entire power supply away from the small clip on its inner edge to remove the power supply.
To reassemble your PS 1 console back together follow the above steps in reverse order.
Compare your new replacement part to the original part You might have to transfer the remaining components or remove adhesive backings from the new part before installing.
Psp
Yes, you need a software to convert a video file to a video format that a PSP supports which is MPEG4/M4V you can check this link for a sample of PSP video converter
http://www.pspvideo9.com/
Hope that helps...........
Can a Sony PlayStation 1 disc be faulty then and not work at all ?
Yes it is possible for a PS 1 disc to be faulty and not work at all. I had that problem with one of my PS 1 disc's was not working so I had bought a second disc of the same game for my PS 1 console and it was working. Try buying a new game disc to see if it works or not if it works then then it was just a faulty disc if it doesn't work at all then your PS 1 console is having a problem with the laser and the lens and the disc drive that needs to be replaced. If it is working on a different system then it could be your PS 1 console. Try a new disc and see if it works first.
Sony playstion 2 Fat scph 30003 - no picture, no sound
There's an option says something like "Audio out" and you can set to Optical or Component (I don't remember quite right), you could try that.
If that doesn't work and the video comes fine out of the composite cable and the audio out of the optical.
Check the cables...
I have a sony blu ray player that I cant get to work with net flix
You need to go online via PC or laptop or tablet to register your device.it must be using the same router.once your device is connected at the sane time as your registered device you can enter the code into the blueray or screen on device.this will allow the blueray to run via internet.I think I am right in saying earlier sony bluerays from Europe/Uk do not run netflix only amazon. The American ones do.
Ps2 multitap
It's the multitap, yours is designed for PS1 games, and PS2 and PS1 games require different multitaps. You have to buy one specifically for PS2.
How to solder a loose wire from a psp go sony charger
First you will need a pin out of the adapter.
Tools you will need are.
1: Solder with rosin core thin solder would be best
2: Soldering iron lower watts the better
3: Flux to clean the surface you want to solder to
4: Sponge to clean the tip of solder iron
If you don't have any of thous supply's it would be cheaper to buy a new cord. Also if you don't have vary much experience soldering i would also recommend getting a new cord for the fact you can cause more damage than good.
To get the solder iron ready you need to heat it up. Once it is hot enough to melt the solder apply the solder to the tip and let is set there until you want to solder. You have to clean the tip off with a wet sponge but not soaked in water just enough to get it wet. Every time you go to solder Clean the tip off and apply fresh solder to it not a lot just enough to cover the tip when you want to solder. When you go to store the iron apply a small blob of solder to the tip to keep it from oxidizing.
Strip the wire shielding off a bit longer than the size of the contact you want to solder. Twist the wire and put flux on the surface you want to solder and tin them.
Tinning the wire is just applying a small amount of solder to the wire as to hold the strands together and make it easier to transfer the heat and solder to the contacts. Now mach the pin-out to the weirs to the contacts and put flux on the contact you want to solder to. Clean the surface by applying flux to it.The surface will be oxidized and will not let you transfer heat or solder to the surface. The key to soldering is to use the right amount of heat , solder and time you hold the iron to what your soldering to. You want to make sure you touch the wire and the contact you are soldering to as to transfer the heat to both items at the same time to make the solder flow. Put the solder wire to the tip of iron that is touching the wire and contact and not on top of the iron tip. Any time you apply heat to solder joints you want to use flux to keep them clean and free of oxidized material. After you solder check the solder joints for cracks, uneven and dull surface. You want the solder to look as shiny as possible and smooth. If it looks like it has waves or holes and cracks it means you have a cold solder joint and must reheat and apply flux with a small amount of solder to fix it .Here is a link to help you out this is not my site and full credit goes to the owner of site.
How To Solder Soldering Tutorial Also put a link to a new cord if you decide you want to get a new one. Here is a link that may or may not help with the pin-out. Also not mine it should credit the poster on the forum as he did all the work i just found it
PSP Go Cradle mini USB Tutorial with Partial Pinout PSP Go Acidmods com
I cant start my ps4
may be you need cdkeys for the game, or your consoles do not work, you need find what prolem actually is, if need cd keys you can have a view on https://ww
w.m8x.com, if your console do not work, you should repair it, if you need FIFA Coins, FUT Coins or FIFA 19 Coins, you can have a view on https://www.
fifacoin.com
I need a cool online gaming name
Hello my friend,if you like first person games try call of duty modern warfare 2,if you like strategy games try warhammer dawn of war 2 or command and conquer 3.If you like role playing games try lineage or world of warcraft.Personally i love call of duty
How can i get cheats in the game?
Online, google the game and console details and add cheats.Generally a list of sites will give cheats for the game selected.Follow the commands
