20 Most Recent
Acer Aspire One D255-2670 Questions & Answers
My acer laptop is stuck on the "resuming windows" screen
Sounds like you have a boot file or system file that is corrupt or missing and you will need an operating system disc to fix the problem. If you have an operating system disc insert it into the CD Drive and boot from it. Look for the recovery console that allows you to get to a window to type in a dos command. The command you want to type is: chkdsk /r This process will run well over an hour and you will notice the percentage of completion going from high to low but that's ok. Let it run to completion then reboot your machine. If the Check Disk utility don't resolve your issue you will need to reinstall your operating system. Depending on your operating system there are ways to do a repair which preserves your docs, music, pictures and videos. Otherwise if you do an install you will lose them unless you have them backed up someplace other than on your computer's C: Local Drive
There is missing system configuration option in acer AOD257 bios
Search for a recent update for your bios. You can also try a different bios all together. Google "Acer AOD257 BIOS Upgrade" and "Acer AOD257 compatible BIOS". I remember my old BIOS having very limited options available. The BIOS I use now has two pages of options. Hope I was able to help!
Acer aspire one D255 will not charge
You don't have a real serious problem. Just use the Power Cord. Now if the Power Cord does not work, that's a real problem. If your power cord is good and you can use your laptop with it, then the problem is your battery is bad if it will not take a charge. It's time for you to buy a new battery.
How to delete spider games in win xp
Start > Control Panel > Add or Remove Programs > Add/Rremove Windows Components on left side. Accessories and Utilities > Details. Games > Details. Remove check from Spider Solitaire. OK.
Keyboard not working
I suggest you (click >>) remove the keyboard, use a toothbrush on the "contact" point on the ribbon cable just below the yellow arrow click here, sometimes they oxidize.
removal then just refitting has been known to cure!
if not new keyboard should be cheap enough.
hope this helps
Computer getting slow..
backup your data and format the computer with a bootable os disk or install another igb RAM memory
