20 Most Recent Seagate Barracuda 40 GB Hard Drive Questions & Answers
2answers
When i format the harddisk that its completly
You'll need to debug your Hard disk to remove your partitions, you will be also needing windows 98 as your temp. OS to the debugging
See microsoft issue regarding "Debugging a hard disk" for you to be guided accordingly
11/5/2009 6:30:43 AM • Seagate... • Answered on Nov 05, 2009
I cannot fromat 40gb segate barracuda ata harddrive
can you have change your used xp2 cd and cd rom
8/11/2009 3:28:02 PM • Seagate... • Answered on Aug 11, 2009
Hard disk not detected but Cd Rom drive detected
reconnect data cable or sat cablew to harddisk
Aslo reattch power cable to it.
Then check in bios that if u have sata then sata must enabled in bios.
5/22/2009 4:56:45 PM • Seagate... • Answered on May 22, 2009
SEAGATE DRIVER ISSUE
It is a internal hard drive, which connects through IDE cable (the wide one), so you shouldn't be asked for drivers. If in any case you can't see this drive in your "My Computer" ("Computer" on Vista) it's probably because you have connected it wrong. Notice that the end of the IDE cable must be connected tou your main hard drive (where OS is instaled). If Seagate ST340015A is your main hard drive, than the end of the cable should be connected to it. If not, than on the same cable, about in the middle is another connection, you should use that one.
3/18/2009 8:35:42 AM • Seagate... • Answered on Mar 18, 2009
2answers
Please share image and location of TVS diode in ST3120827AS seagate hard disk circuit board
For the Seagate hard disk model ST3120827AS, the TVS diode is typically located on the circuit board (PCB). TVS diodes are designed to protect electronic circuits from voltage spikes and transient events. They are usually small, with two leads, and look like small cylindrical or rectangular components.To locate the TVS diode on the circuit board, you may need to refer to the hard drive's datasheet or schematic diagram, if available. Additionally, you can try searching for online resources or forums where individuals share information about hard drive components and their locations.Regarding the Cisco Nexus Network Switch , it's important to note that specific details about the internal components, including the location of TVS diodes, may be proprietary and not readily available in publicly accessible documents. For detailed information about the switch's internal components, you may need to refer to Cisco's official documentation or contact Cisco's supporthttps://www.serverblink.com/n3k-c31108pc-v-cisco-nexus-network-switch/
2/19/2024 8:12:49 PM • Seagate... • Answered on Feb 19, 2024
The hard disk not detected
Try downloading TESTDISK and see if the drive is detected on the List within TESTDISK. If it is then you may be able to restore the boot sector within TESTDISK.
5/22/2019 10:07:55 AM • Seagate... • Answered on May 22, 2019
Seagate barracuda 7200.9 connect to USB
You will need an external Hard drive adapter case. This will probably come with driver disk. If already and external drive it may have internal firmware which talks directly to the PC. Just install drivers, if any, and plug unit in. Follow screen prompts.
11/23/2017 3:49:02 PM • Seagate... • Answered on Nov 23, 2017
Can a power interrupt during hard drive installation cause a "Boot manager missing" message?
You do not say what OS you were installing, and Windows limits what you can do with the hard drive during installation. As you have found out, any power interruption during an installation will likely corrupt the process and make the system unbootable. If you can restart the install at the very beginning that may work for you. However, I believe the simplest fix will be to use a live system bootable disk and erase the corrupted partition table on the drive then restart the install as if it were a brand new hard drive. For that type of recovery I use gparted, which can be downloaded for free from http://gparted.org/livecd.php Gparted live can be used on CD, hard disk, USB, or even pxe boot. I would delete all the existing partitions that were created during the failed install, then restart the install from the very beginning as if it were a new disk.
3/10/2017 6:40:44 PM • Seagate... • Answered on Mar 10, 2017
2answers
IDE to sata adaptor +barracuda 500GB HDD
5/17/2016 11:53:59 AM • Seagate... • Answered on May 17, 2016
Configure subnet
5/17/2016 10:47:20 AM • Seagate... • Answered on May 17, 2016
Format a 320gb seagate for xbox 360
5/17/2016 10:46:17 AM • Seagate... • Answered on May 17, 2016
Hdd
5/17/2016 10:39:20 AM • Seagate... • Answered on May 17, 2016
I had a desktop crash.the pc shop tod me it was the hardrive, and replaced it. I still have the old one. Question 1 why cannot the disk be replaced.2 how do I retrieve data off the old drive?
The hard disk must have crashed and only professional data recovery service providers can retrieve data from the hard disk. It will cost money and if the data is extremely important then only you should opt for data recovery.
3/11/2016 6:07:43 AM • Seagate... • Answered on Mar 11, 2016
How do you retrieve photos from a hard drive
You mean "lost" photos? or I don't understand your question. If lost, there are a number of "free" recovery software solutions as well as purchase type solutions. Otherwise, tomshardware.com has very good answers.
5/5/2015 2:21:55 AM • Seagate... • Answered on May 05, 2015
How do I get a computer picture on my Samsung TV after installing Seagate hard drive? What I get is "Mode not supported"
The picture is in the wrong format, try Jpeg.
1/23/2015 10:13:10 AM • Seagate... • Answered on Jan 23, 2015
3answers
Can I fix my Seagate hard drive to bootable?
Hi, two things to try. 1. If you have the Win7 cd/dvd, go here and read: http://www.bleepingcomputer.com/tutorials/start-the-windows-7-recovery-environment/ But I'm thinking that you have a few bad sectors in the HD's boot area (educed from your tzak.tzak description - which is head seek (bang) trying to find the boot sectors). Which I'm not sure that Win7 recovery can cope with. But check out this link and read/follow links: https://answers.microsoft.com/en-us/windows/forum/windows_7-system/how-to-fix-the-boot-sector-of-windows-7/deb6ad12-a6b1-46fc-9786-240f66f9143e And this link (better?): https://answers.microsoft.com/en-us/windows/forum/windows_7-system/restoring-windows-7s-master-boot-sector-to/435f7bf7-9d5b-4741-9746-945ff06e6251 or 2. Go here and get SystemRescueCd: http://www.sysresccd.org/SystemRescueCd_Homepage It contains many tools for the repair of malfed systems. You will want to use this tool: TestDisk TestDisk[4] Popular disk recovery software. Recovers lost partitions and repairs unbootable systems by repairing boot sectors. It can also be used to recover deleted files from FAT, NTFS and ext2 filesystems. File system recovery is supported for reiserfs, ntfs, fat32, ext2/3 and many others. In closing, I would get a new HD, maybe a SSD? to replace your original hard drive (It may be failing, or it took a hard knock while in the boot phase, causing head-bang in the boot sector - not good). Make the new drive your master and use the old one for misc. data that you have originals of, i.e. music cd's, dvd movies, programs off-loaded from Tivo/DVR, etc. Hope this at least gets you going in the right direction...
11/7/2014 5:06:41 PM • Seagate... • Answered on Nov 07, 2014
Seagate BARRACUDA squeaking
Backup data and replace drive ASAP.
8/23/2014 11:49:26 AM • Seagate... • Answered on Aug 23, 2014
Seagate 2tb external hard drive stopped working,how can i retreive data
Pry open and try connect SATA drive to motherboard directly.
8/23/2014 11:48:36 AM • Seagate... • Answered on Aug 23, 2014
What can i do if my hard driver can not load Windows 7 Ultimate due to missing drivers
You'll need to restart the formatting and installation of the OS.
8/22/2014 7:16:08 PM • Seagate... • Answered on Aug 22, 2014
My 120 Gb seagate Sata harddisk got fired due to high voltage shock. What can i do. Is there any way i can reapair it. Is there any way i can replace the logic board of it with 80 Gb board and try.
I understand the value of the files that resides on the disk:) Yes! It is possible that harddisk may back to life by replacing the logic board but of the same model or part number. If it is not possible by replacing logic board due to other defects such as head crash and spindle drive motor opened/shorted, there still a big chance to recover depending how you value the data on it by contacting international Seagate Data Recovery support service with considerable service fee. Hope this helps.
3/4/2014 11:21:20 AM • Seagate... • Answered on Mar 04, 2014
Seagate Barracuda 40 GB Hard Drive Logo
6 questions posted
Top Seagate Computers & Internet Experts
Sean Wright
Sean Wright
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
BARRACUDA Seagate
  • BARRACUDA Seagate
Most Popular Question
when format harddisk its completly
  • Computers & Internet
