20 Most Recent Polaroid PDV-0701A Portable DVD Player Questions & Answers
Disc plays but no sound
The problem can be in the laser pickup assembly all the way to a bad speaker, try headphones to see if audio is present, if yes! the earphone jack, speaker, and audio output chip is the issue, if no sound! it is more than likely the assembly.
4/16/2012 4:59:34 PM • Polaroid... • Answered on Apr 16, 2012
0answers
0answers
MY POLAROID PORTABLE DVD PLAYER MODEL PDM 0711
the problem is from your screen inverter or screen flex. either of the two is defective, that's why the screen is misbehaving. This is very common with portable DVD players. The flex or inverter gets worn out as a result of constant opening and close of the player.
To confirm connect the player to your TV via the AV Out on the player.
Good luck.
11/9/2010 9:21:07 PM • Polaroid... • Answered on Nov 09, 2010
2answers
Sound, but no picture
Initially, this would either be a defective LCD panel or its interface. A way to verify is to play the portable DVD using an external video monitor such as your TV. If still gray or blue screen (no video) even in the TV/monitor, then it would be the video interface/circuitry. If the video is displayed, then it would just be the LCD panel display.
If it turns out to be the LCD display, it is very possible that it is a backlighting issue. Most likely, it would be in the inverter and/or CCF (cold cathode florescent) lamps. This is a relatively easy repair by re-soldering. It is perhaps more of a task to open the panel lid/cover of the LCD display.
This of course would require a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
6/29/2010 9:52:07 PM • Polaroid... • Answered on Jun 29, 2010
Polaroid portable dvd player problem
My screen on my dvd player is dark
12/15/2009 9:06:17 PM • Polaroid... • Answered on Dec 15, 2009
PDM-0722 Screen showing upside down
I don't own this, but I just looked up the Manual. If it's a picture on the screen, using the arrow (Direction buttons) will rotate the screen. Also is looks like the Mode button may also change the orientation of the screen. Hope that does something for you
9/21/2009 6:00:01 PM • Polaroid... • Answered on Sep 21, 2009
The speakers are very staticky. Is there anything
Hi , this is a common problem with this type of dvd player it starts happening after it has been used for a while the problem is actually with the speakers they tend to start getting this problem after regular use.
Their isnt an easy fix for this problem the only wat to solve this problem is to get the speakers replaced if you take it to repair shop they will do this for you.
On your model if you have a setup menu you can enter the sound options and turn down the bass and treble a bit doing this might reduce the crackle but it wont be long term fix.
sorry their is know easy fix for this.
Do you get this sound whilst using head phones or just the internal speakers if you get the crackling noise through headphones also then the chances are the lense needs replacing if you have tried a good lense cleaner then replacing parts is the only way to solve the problem your having.
Let me know how you get on or if you need further assistance ok
8/11/2009 3:37:34 PM • Polaroid... • Answered on Aug 11, 2009
Polaroid Portable DVD won't work
First try a couple more discs. If it still doesn't work. Take a little bit of alcohol on a qtip and clean off the little clear circle under the lid. Make sure the dics you are using a not scraped and not foreign. If that doesn't work, order a new one and put the old one in the new box and send it back as broken.
6/28/2009 6:27:03 AM • Polaroid... • Answered on Jun 28, 2009
Dvd player will load dvd and then no disc message
Iam having the same problem with mine. I also need help.
6/28/2009 5:09:58 AM • Polaroid... • Answered on Jun 28, 2009
3answers
DVD cords
You can buy a new one by clicking on the hyperlink:
buy replacement ac adapter power charger cord for POLAROID pdv-0701a pdv0701a
5/31/2009 7:50:56 PM • Polaroid... • Answered on May 31, 2009
2answers
Discs will not turn
Dear dmiller,this is a common problem with dvd players.Most probably the optical assembly of your player has gone bad.Please get it checked by some good technician.Replacing this unit should solve your problem.Thanks.
2/7/2009 2:50:45 AM • Polaroid... • Answered on Feb 07, 2009
Input to 3.5mm jacks
this unit should work great for that...it has an A/V in/out switch so you can use it as a monitor...I plug output from a cable tv box into and we use it to watch tv
1/4/2009 4:43:01 PM • Polaroid... • Answered on Jan 04, 2009
3answers
All I see is a blank blue screen on polaroid dvd player
try pressing the in/out button that should fix a blank blue screen
1/3/2009 8:12:38 PM • Polaroid... • Answered on Jan 03, 2009
2answers
"No Disc" Error
cleaned your lens with 100% cotton buds, if not work again change the laser eye. do it!!!
11/25/2008 12:11:17 AM • Polaroid... • Answered on Nov 25, 2008
No picture on screen
8/30/2008 9:16:56 AM • Polaroid... • Answered on Aug 30, 2008
Polaroid PDV-0701A Portable DVD Player Logo
25 questions posted
Top Polaroid Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Polaroid Televison & Video
Most Popular Question
pdm 0722 screen showing upside down
  • Televison & Video
