20 Most Recent Iomega 34611 500 GB USB Hard Drive Questions & Answers
MON DISQUE DUR NE SE CONNECTE PLUS A MON
Bonjour.
Connectez le disque dur a autre ordinateur en utilisant un cable USB different u s'il vous plait. Si cela ne fonctionne pas sur le disque dur doit etre retire del boitier et utilise un boitier de disque dur different.
Voici un article en anglais sur le meme probl?me:
8/7/2011 12:07:02 PM • Iomega 34611 500... • Answered on Aug 07, 2011
Where can I fined user
Select Portable Hard Drive USB 2.0 User's Manual: View Online [HTML] ' Download [398KB zipped HTML]
Quick Start Guide [PDF 1.1MB]
Specifications
12/27/2010 6:39:33 AM • Iomega 34611 500... • Answered on Dec 27, 2010
Formated on one PC, files
do have fat32 on one and ntfs on other?
12/26/2010 9:15:29 PM • Iomega 34611 500... • Answered on Dec 26, 2010
MY 34611 500 GB USB Hard Drive IS GIVING A SQEECKY
Unusual noise ets are indications of mechanical failure and as your drive cannot be detected by the system, it is best to claim the warranty as soon as possible and get the replacement.
GoodLuck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
12/9/2010 9:50:59 AM • Iomega 34611 500... • Answered on Dec 09, 2010
When i plug in my
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
11/29/2010 8:47:47 AM • Iomega 34611 500... • Answered on Nov 29, 2010
Iomega 1TB ScreenPlay DX HD Media Player. I am looking for a Wi-Fi adaptor please?
What about this? Have you contacted Iomega Support to ask for alternatives? https://40kskudemo.scandipwa.com/default/iomega-screenplay-wifi-adapter-3970824.html ..
4/16/2023 2:52:16 AM • Iomega Computers... • Answered on Apr 16, 2023
When i connect my iomega to power cable on light comes on,also when connect to pc my pc can't find it.
Re instal the drivers and software. It is a PC and won't work without drivers.
2/24/2021 2:15:15 PM • Iomega Computers... • Answered on Feb 24, 2021
Driver iomega zip 100 printer interface
this device is now obsolete. (windows 10 does not support it) why try to use this? use thumb drive USB or the CLOUD.
12/10/2019 12:04:19 PM • Iomega Computers... • Answered on Dec 10, 2019
I need a user manual for the Iomega GDHDU
http://www.sb.fsu.edu/~xray/Manuals/Iomega-EHD.pdf the link above is a user manual. good luck.
10/28/2019 4:32:25 PM • Iomega Computers... • Answered on Oct 28, 2019
I'm running OS 10.13.6 on a mac book pro. My Iomega MDHD500-TE is not recognized. What to do?
I suspect that you don't have an Iomega driver in play for use with this Macbook pro that the OS recognizes. There are other possible explanations, you might have a corrupted volume or there might be a problem with the file structure on the Iomega. But if the Iomega was not previously recognized by this MacPro, I think what is missing is a useful driver. You might try one of the driver hunter utilities and see if it finds such for the iomega. If several are found, you would have to try each one at a time and uninstall any that did not work before trying the next, I think. Here is something else you might try. On the MacPro, on the desktop go into Applications>Utility folder and from the Utilities folder launch the Disk Utility application. If your Iomega is discoverable, it will show up in the left side of the Utility window. If you see it, click on the left side of the window and choose Disk Repair. If you don't see it in the left side of the Utility window, you may have a corrupted volume preventing it from properly being read on your Mac or there may be a problem with the file structure of the Iomega.
4/17/2019 3:04:13 AM • Iomega Computers... • Answered on Apr 17, 2019
My tereabyte drive is 'empty' except for a small megabyte file but when I look at properties, about 200 GIGAbyte are used..but by what I don't know! can anyone tell me what that much space
change view file settings to un hide and then have a look it will probably be recovery files. or at some point its been changed to use as an extra ram file.
1/15/2018 6:55:03 AM • Iomega Computers... • Answered on Jan 15, 2018
I loaded a number of files awhile ago on my ex
Try going to contol panel then administrative tools. In the window that opens look at the left window pane for disk management click on it. You should see the disk that says you need to format it, Compare file systems your c drive and the disk you can't read. (Fat32, NTFS, Fat) Right click on the disk that's giving you problems and see if Vista will let you mount the drive. If it won't you should put the drive in a portable enclosure and use a Windows 7 PC to Burn your files to disc. Vista is extremely unstable If you can load Windows 7 your problem will go away and you'll have a way better OS!
1/3/2018 10:45:58 AM • Iomega Computers... • Answered on Jan 03, 2018
I have a screenplay hd iomega external hard drive . i was using it without any problems as i have been for the last 2 year i left my computer for 1 min and when i got back i could not conect to my har
I would start with removing HDD from IOmega enclosure. There is some hope, that it's not a hard drive which failed, but SATA controller in enclosure. Then you will need to connect this HDD to a known working PC and scan it using MHDD. This tool will show you if your hard drive is failing and how bad it is.
And regarding data recovery - as far as I know IOmega uses Linux file system, so you will need to boot some Live Linux Distro to get access to your files.
12/25/2017 7:13:53 PM • Iomega Computers... • Answered on Dec 25, 2017
I have an 2005 iomega
Whatcha got a do is check yer properties, if it's full you'll have to reformat the disk to FAT32 then git the files an zip em up an transfer em over that way an you should be all good..
12/4/2017 7:41:21 AM • Iomega Computers... • Answered on Dec 04, 2017
My drive may have shorted out
Drive did not short out.. It DIED. There is a difference.
8/28/2017 6:47:04 PM • Iomega Computers... • Answered on Aug 28, 2017
Iomega 34611 500 GB USB Hard Drive Logo
8 questions posted
Top Iomega Computers & Internet Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Jerry Naidoo
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Iomega Computers & Internet
Most Popular Question
mon disque dur ne se connecte plus mon
  • Computers & Internet
